So after someone tipped my bike over, I recieved a healthy check from insurance, and because I'm doing the work... I choose the parts
. This time around I'm inspired by a more "racing" influence. Needless to say, I believe I'm ditching all my spiked parts.Here's a sneak peak at the redesign so far... DIY Mods Hidden clutch cable Stretched gas tank/ cut seat. Shaved gas tank seams Relocated gas tank vents Brushed all chrome Starter switch relocation: micro switch under tank Right side cover: Ignition hidden inside fake NOS bottle Shaved triple trees Tach relocation: http://www.rswarrior.com/forums/14-installed-warrior-modifications-accessories/112730-headlight-tach-key-reloc-int-wiring-31-pics.html Rectifier relocation: Relocate Rectifier "How To" Coil relocation: http://www.freewebs.com/roadstarwarrior/coil_relocation.htm Brake switch/horn relocation: http://www.rswarrior.com/forums/14-installed-warrior-modifications-accessories/164339-my-own-twist-jarvs-right-side-brake-tidy-up.html Internal wiring (frame): http://www.rswarrior.com/forums/14-installed-warrior-modifications-accessories/112730-headlight-tach-key-reloc-int-wiring-31-pics.html VBAK: http://www.freewebs.com/roadstarwarrior/coil_relocation.htm Exhaust: http://www.rswarrior.com/forums/21-how-tos-general-maintenance-tips/177446-diy-exhaust-how.html Rear brake reservoir relocatoin: http://www.rswarrior.com/forums/14-installed-warrior-modifications-accessories/152130-diy-relocate-rear-brake-reservoir.html Flip & Grind: The Flip: Lower your Roadstar the Fatbike way... - Yamaha Road Star Fender bobbed: http://www.rswarrior.com/forums/14-installed-warrior-modifications-accessories/112361-lowered-rear-fender-chop-done-page-1-a.html Other Mods KyleNV 280mm wheel kit Internal throttle '08 R1 radial mastercylinder R1 adjustable levers Vrod headlight- mounted with ProTek 54mm fork tube clamps Drag Specialities Euro risers Drag bars Russell stainless brake line. Internal frame wiring ![]() ![]() Frame after coil relocation and rectifier relocation ![]() Here's a link to the "how to" on the exhaust build. DIY Exhaust "how to" ![]() Right side cover: Fake nitrous tank, drilled the bottom of the tank to thread the ignition in. Drilled the top of the tank and the valve/hose to run ignition wires through and up under gas tank. ![]() ![]() Final tear down and assembly. Updated 8/20/12 ![]() ![]() ![]() ![]() Tank seam shaved smooth ![]() ![]() ![]() ![]() TANK STRETCHING!! ![]() ![]() ![]() ![]()
------------- -------------My Pics ..... DIY Mods List ..... Popular Mods ..... KyleNV wide tire kits and more Last edited by wyomingwarrior; 12-28-2012 at 08:57 PM. Reason: . |
Make it happen Wyoming!
I have a "mancave" which is where I`ll do the work.
NJWarrior- I think I`ll wait till spring to post the pics. BUT I don`t think I could keep them to myself for that long so I`ll keep ya`ll posted as I go ![]() I have listed the exhaust, grips, risers, and internal throttle in the classifieds.
Who made that swingarm? It looks really clean, great job.
![]() Night Demon - Warrior of the Year Winner - Completed Mods First official ride with the Demon - Another relax ride Friends call me Floren, join the Roadstar Warriors group on Facebook "If you are not sure, just open the throttle" |
Gilly's right, it is a pic of Kyle's 280 swing arm. I just shipped out my swing arm and wheel to him yesterday and just got my Metzler 280 as well.
Headlight- is actually an aftermarket Vrod headlight (don't have it yet). I just need to find some 54mm fork clamps that I can modify for some mounting brackets. I'm going to run an internal twist clutch and therefore needed a small pulley to be machined to attach to the clutch lever to give me a bit of mechanical advantage and I just received a call today that it's finished. Will post pics later. Exhaust- I was going to sell my modified 3" big straights but when I removed them I noticed when the bike was tipped over, the weld on the lower pipe for the rear hanger tore a hole in the lower pipe. SO... I've decided to chop them more. Here's a pic of the mock up. It's pretty much going to be just straight up "strictly business" attitude. They'll be made the same way I did them orginally.. just shorter and straight. I'm also thinking of painting them with a flat silver/grey header paint. DISREGARD THE SIDE PLATE!! That was a cool idea in my head but was quickly scrapped after seeing it on the bike lol
------------- -------------My Pics ..... DIY Mods List ..... Popular Mods ..... KyleNV wide tire kits and more Last edited by wyomingwarrior; 09-13-2011 at 02:46 PM. Reason: add pics |
