Left side engine intake - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 07-30-2012, 11:01 PM   #1 (permalink)
Link71's Avatar
Default Left side engine intake
I know...newb question....just bought an 04 warrior and curious as to what the left side intake is for as the air cleaner is on the right side......sorry for such a tard question...guess i can just take the cover off and look for myself
Link71 is online now   Reply With Quote
Old 07-30-2012, 11:02 PM   #2 (permalink)
Yep you could
It covers all the plumbing for the AIS which most of us remove. It also directs air to the rear cylinder. It doesn't have a filter or anything though.
Old 07-30-2012, 11:03 PM   #3 (permalink)
New_Warrior's Avatar
Covers the Fuel Dry breaks and the motor mount
New_Warrior is online now   Reply With Quote
Old 07-30-2012, 11:13 PM   #4 (permalink)
Link71's Avatar
What is the AIS and why remove it?
Old 07-30-2012, 11:19 PM   #5 (permalink)
AIS is air induction system. The bike is tuned for stock pipes. The AIS pumps recirculated air (I believe) back into the cylinders. When you change out pipes to aftermarket pipes you get a lot of popping and backfiring. Removing the AIS pump, hoses etc. and blocking off the ports where it went into the cylinders will eliminate almost all of that. You can get the blockoff plates for 20 bucks, or just make your own out of sheet metal for free.
Once you remove the AIS plumbing, then what is left behind the cover is the engine mount and the dry break (fuel line). You can by a streamlined motor mount from KyleNV, and then buy a nice aftermarket dry break and do a left side clean up, where you basically have a stripped engine on the left side.
Edit: I guess it's actually fresh air (not recirculated) that gets pumped into the cylinder after the exhaust valve. I never really paid much attention I was too busy tearing it out
Old 07-30-2012, 11:24 PM   #6 (permalink)
Link71's Avatar
i see......i will check and see if it has already removed, the previous owner installed V & H bigshots, PCM3....and K & n filters right onto the throttle bodies ( i am sure there is a term for this mod)
Thanks for the info
Old 07-30-2012, 11:26 PM   #7 (permalink)
That would be known as a "BAK" or Big Air Kit.
If you want to read how to do it, and see pictures of what it looks like, click on my link to Redhorse Mods.
Old 07-30-2012, 11:41 PM   #8 (permalink)
Link71's Avatar
Speaking of the "BAK" mod...is it normal to hear a kind of "lobbing" sound from the throttle bodies when giving it some throttle?
Old 07-30-2012, 11:41 PM   #9 (permalink)
Ama
Ama's Avatar
Make sure to upload some pics, alot of people including myself just prefer the naked look of the engine without anything covering it
Old 07-30-2012, 11:43 PM   #10 (permalink)
Yeah, I'd say that. Never really thought about it.
