Rear tire and swingarm - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-26-2012, 04:57 AM   #1 (permalink)
IslamDiab's Avatar
Default Rear tire and swingarm
i want to ask whats the maximum tire that i can install on the Stock swing arm becuase with the measures its seems that the 240 tire will fit in but will be there any issues or complications with this idea or nt ?
IslamDiab is online now   Reply With Quote
Old 11-26-2012, 05:22 AM   #2 (permalink)
The stock swingarm and rear wheel accept a 210mm wide rear tire, but they are hard to find. The 240mm rear tire requires a wider wheel and widening work can be done by some shops. The 240 also requires swing arm modification that can be done at home.
Here's a couple examples I found by searching for "240 swing arm" as search criteria.
Stock swing arm 240 mod
Mods...Fitting 250 rear
Old 11-26-2012, 03:06 PM   #3 (permalink)
Sherriism's Avatar
BAM! Always!
Sherriism is offline   Reply With Quote
Old 11-26-2012, 10:09 PM   #4 (permalink)
Yep they are all correct!
rcoligan2 is online now   Reply With Quote
