low fuel light flashing - Page 4 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 02-28-2007, 10:12 PM   #31 (permalink)
Default Re: low fuel light flashing
how could he ride the next day if his dry breaks were not seated? dont get to far on the pressure tank.
how would his dry breaks just come loose? if he does not know where or what they are he has not taken them apart and not properly seated them. Its an 05 cant blame the factory. Just my 2 cents the fuel light dont blink on these bikes you got and electrical problem some where
the consistant 8 blinks is a sign of more than a dry break problem and a short would not be consistant like that and pop a fuse by now
Good luck with this post your findings
Brad10541 is offline   Reply With Quote
Old 03-01-2007, 01:21 PM   #32 (permalink)
I'm not the first to have this problem. I did a search of this website and found thread below. I can't find loose wire in mine so I sent him an e-mail. Called local Yamaha shops and not getting much help so far today, will keep trying. Thanks
http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=25157&SearchTerms=fuel,light,fl ashing,8
cornholio is offline   Reply With Quote
Old 03-01-2007, 01:42 PM   #33 (permalink)
gchalifo's Avatar
Nice, good searchin Rob. I hope this is it for ya man!.
Old 03-02-2007, 07:39 AM   #34 (permalink)
Local Yami shop ain't going to be any help here. I will go ohm mine out at the sender and see what I get. I use die electric/Spelling? grease on all of my connectors, Like the stuff you use on spark plug boots to keep corrosion to a minium. I would plug and un plug each conector a few times just to make sure the problem isn't a bad connection .
xharleyrdr is offline   Reply With Quote
Old 03-02-2007, 09:59 AM   #35 (permalink)
I'm going to put it back together (haven't pulled pump out yet), clean and add silicon di-electric to all connections, fill tank and pour in some Chevron Techroline fuel system cleaner
concentrate in it. I'm hoping the sender is just contaminated with sulfur (common issue with cars) and that stuff cleans it up real good. I'll keep ya'll posted, I hope that fixes it. Thanks xharleyrdr
Old 03-03-2007, 06:16 PM   #36 (permalink)
arwarrior's Avatar
Sorry it wasn't the drybreaks. That's such an easy fix (99.9% of the time).
arwarrior is offline   Reply With Quote
Old 03-10-2007, 10:58 PM   #37 (permalink)
Update, took bike into dealer today for both recalls ( t/p and crank sensors) and for them to check out why fuel light flashes. Should know something by next week. I was tempted not to take it in so I could ride during spring break, o well. Turns out the service manager lives around the block from me!
Old 04-19-2010, 03:16 PM   #38 (permalink)
If the light flashes 8 times then stops for a couple of seconds then blinks again 8 times and keeps on doing this it is a faulty fuel sending unit. I just went thru the same thing with mine and took it all apart and it tested OK electrically but as soon as I replaced it and ran the engine for a few minutes all was back to normal. This is a common problem with the fuel sending units on these bikes. Fairly easy to do and costs about $65.00-$70.00 us dollars
skinnystar is offline   Reply With Quote
Old 04-19-2010, 05:20 PM   #39 (permalink)
68ramair's Avatar
Don't know if you noticed or not skinny, but this post is 3 years old and the poster hasn't been here in 2 years.
https://maps.google.com/maps/ms?ie=U...9f2e66c8dcf24b
Old 11-03-2012, 01:56 AM   #40 (permalink)
BrutalPancho's Avatar
Interesting (and slightly entertaining thread)
I actually have the exact same 8 blinking sequence problem on my fuel light.
I suspect too that it's just a flaw with these fuel pumps.
Not sure how I can fix it for $65 or $70 us dollars tho?
