#41 (permalink) | |
right here https://www.google.com/url?q=http://...6gEevWYuVGX0wQ Last edited by iowawarrior; 11-03-2012 at 07:02 AM. |
#42 (permalink) |
Skinny said it was a sending unit, not the pump. I don't know if he is right, but those aren't the same...
Sent from my DROID RAZR
#43 (permalink) |
Yeah, the pump is working fine and bike is running as it should (like a beast)! Just the flashing light thing... I'm getting used to it and just reset the trip comp to zero at each full tank and get more after 100k's just so I dont run out.
Shame they dont have a real needle gauge. Anyway Im used to bikes with NO gauge or light But from my limited and rather new to Warrior learning curve, I think the sender etc is inside the actual pump anyway.ps: thanks to everyone on here for helping me cram in the knowledge. Great forum! |
#44 (permalink) | |||
This is covered in the Owner's Manuals starting I think with the 2005 Owner's Manual. The Service Manual did not receive this information. The fuel light blinking 8 times and repeating indicates a circuit issue with the fuel level sending unit not an issue with the fuel pump.
One reported 'fix' was to re-connect the sending unit wire inside the aux tank that comes off the sending unit (not a common thing to come loose). Most other times its been a corroded coupling-plug on the aux tank, or physical damage to the green wire in the aux tank coupling-plug. That green wire goes to the fuel light in the gauge. From Page 3-2 of the 2007 OWNER'S manual: This model is also equipped with a self diagnosis device for the fuel level detection circuit. If the fuel level detection circuit is defective, the following cycle will be repeated until the malfunction is corrected: The fuel level warning light will flash eight times, and then go off for 3.0 seconds. If this occurs, have a Yamaha dealer check the vehicle. Here's a pic that was done for another purpose but will maybe be of help here. I've wondered if its possible if the aux tank is left empty enough to expose the wire connections to air over a winter in storage maybe the sending unit connections can corrode inside the aux tank. The top connector to the bike isn't shown but there could be corrosion in that plug. ![]() Quote:
![]() My Pics Great Members Popular Mods Model Year Differences Group Rides WyomingDIY KyleNV Technical Last edited by arizonawarrior; 11-04-2012 at 04:02 AM. |
#46 (permalink) |
So this remains an unsolved mystery as far as Cornholio's problem is concerned. He never posted if the problem was solved. He posted for over a year after this problem with no reference to any outcome, then disappeared never to be heard from again.
Those who post here looking for help with problems should follow up with the results. It only helps the rest of us who were trying to help to begin with. I know most of us do, just saying for future reference.
#47 (permalink) | ||
He updated his OP with his fix. Over time afterward several members discovered it wasn't always necessary to replace the sending unit (ie replace the entire pump assy to get the sending unit) but instead members found the items I mentioned earlier (green wire damaged, couplings corroded inside the tank but more often outside the tank). I believe the couple of guys who replaced their fuel pumps in the last year had verified they had actual pump failures.
![]() My Pics Great Members Popular Mods Model Year Differences Group Rides WyomingDIY KyleNV Technical Last edited by arizonawarrior; 11-04-2012 at 12:58 PM. |
