ignition - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-24-2012, 03:26 AM   #1 (permalink)
Default ignition
Hey does anyone know how to remove the ignition switch from the triple trees. I want to sent them out to be chromed. Thanks in advance.
Law369 is offline   Reply With Quote
Old 11-24-2012, 06:17 AM   #2 (permalink)
Take a dremel tool and cut a slot down the center of the bolt heads so a screw driver will be able to turn them. Then take a propane torch and heat them up because they have red lock tight on them. When you get them hot enough the bolts will unscrew. Be careful not to over heat things. Concentrate the heat on the bolt heads.
Old 11-24-2012, 01:01 PM   #3 (permalink)
Okay thanks.
