Unused connector - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-28-2012, 12:51 PM   #1 (permalink)
Default Unused connector
I have an unused connector with 1 red and 1 black wire. The red wire comes from the positive battery cable; the black wire comes from the ground side of the starter relay. the connector is white. Any clues?
texkiernan is offline   Reply With Quote
Old 11-28-2012, 12:55 PM   #2 (permalink)
kayak101's Avatar
do you have a picture?
03 Warrior
Old 11-28-2012, 12:59 PM   #3 (permalink)
jimmy2's Avatar
You the origional owner??
Maybe someone had a battery tender before
and that may have been the quick disconnect...
jimmy2 is offline   Reply With Quote
Old 11-28-2012, 01:28 PM   #4 (permalink)
I am not the original owner, I just bought the bike last month. Here are some pix. It also has a PCIII Serial installed. The first picture shows the connetor laying beside oil filler cap.
Old 11-28-2012, 01:49 PM   #5 (permalink)
LASTCHANCE's Avatar
Think Jimmy2 has it right for a charger, with those two connections it can't run anything on the bike unless it was for some 12v accessory that didn't come with it.
LASTCHANCE is offline   Reply With Quote
Old 11-28-2012, 02:07 PM   #6 (permalink)
BiggG's Avatar
Looks just like the Battery Tender Connector.....except some have the black cover with a snap on lid.
Old 11-28-2012, 02:36 PM   #7 (permalink)
Yeah, based on the gauge of the wire, I would guess battery tender connection too...
I can look under my seat tonight if you want to confirm this....I will post up again tonight.
Old 11-28-2012, 02:43 PM   #8 (permalink)
I agree, it is from some type of battery connector but not from the brand Battery Tender, they look totally different.
Old 11-28-2012, 02:46 PM   #9 (permalink)
The black wire at the starter relay powers the starter motor. I don't have a MC alarm system and different ones work in different ways so maybe that's what its for, to sense the key is 'on' indicating the owner is starting the bike and not a crook, and from that allowing the bike to start normally without the need to enter a code or press a remote-button or some such. Or maybe its for some other item that wants to know when the starter motor is cranking (its not the decompression solenoid). Or its remotely possible that someone installed something incorrectly and abandoned it in place. In any event, removing the connector won't do any harm and happily the wiring diagram can be checked to see there's no such stock connector at that point.
Old 11-28-2012, 03:53 PM   #10 (permalink)
Thanks for everyones advice. arizonawarrior, is it being used as a bypass to the relay ground since it basically bridges the relay for whatever component is plugged in to it?
