Please Help! - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 12-08-2012, 01:40 PM   #1 (permalink)
Hamz4ua's Avatar
Default Please Help!
I recently loosened the 8 hex bolts surrounding the forks to get handlebars straight and the font end sagged down. How do i fix this problem?? How do i get fork braces back up??
Hamz4ua is offline   Reply With Quote
Old 12-08-2012, 01:41 PM   #2 (permalink)
Hamz4ua's Avatar
Another image
Old 12-08-2012, 02:12 PM   #3 (permalink)
whajac's Avatar
If it were me, I'd slide my m/c jack under the bike and just barely lift it to get it level. Loosen the said 8 bolts again then slowly start to lift the bike until the forks find their way to their previous location. They may need some persuasion. Do you have a m/c jack, bet not? You can also find the Warrior Service Manual on site here and follow instructions for fork removal which includes removing the brakes and wheel and fender.
<a href=http://i200.photobucket.com/albums/aa57/whajac/948c1a42-8cc8-460a-a86a-f93f6f1dcdab_zps1373d138.jpg target=_blank>http://i200.photobucket.com/albums/a...ps1373d138.jpg</a>
whajac is offline   Reply With Quote
Old 12-08-2012, 02:27 PM   #4 (permalink)
jabo's Avatar
Very simple fix. if you don't have a motorcycle jack, just have a friend hod the bike from tipping and you can use a floor jack. Just make sure the jack is contacting a sturdy location and lift only the front end. If you need too, gently tap the top of the fork with a rubber mallet or soft wood. Additionally it helps if your friend is fairly stout. The mc jack is the best solution if you have one.
Old 12-08-2012, 02:28 PM   #5 (permalink)
jabo's Avatar
Where do you live? There may be some 4m buds that are close enough to give you a hand.
Old 12-08-2012, 02:44 PM   #6 (permalink)
twicechosen's Avatar
Nothing like joining the 4m and getting help immediately! Listen to the advice given and they will set you straight. Welcome.
Stay in the word!
Member 24379
Old 12-08-2012, 06:23 PM   #7 (permalink)
Hamz4ua's Avatar
I appreciate all the help! I jacked it up and got them back down. It was a simple fix... just had to work them a little more than i expected.
Old 12-08-2012, 07:14 PM   #8 (permalink)
jabo's Avatar
Well done.
Old 12-08-2012, 09:56 PM   #9 (permalink)
Welcome to the family!
The DarkMidKnightWarrior
rcoligan2 is online now   Reply With Quote
Old 12-08-2012, 10:22 PM   #10 (permalink)
bruce59's Avatar
Be careful not to over torque those pinch bolts on the forks or you can cause yourself a lot of grief such as broken triple tree. When you do torque them , do it by degrees and then recheck because you can have one torqued to spec and then when you tighten the next one , the first one will be loose again.
What is the issue with the handlebars?
bruce59 is offline   Reply With Quote
