Avon tires cracked - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 03-19-2017, 09:45 PM   #1 (permalink)
Greg99a's Avatar
Default Avon tires cracked
So my tires are a little over a year old, and I noticed this today. It's on both sides of the rear tire only. Any suggestions?
Greg99a is offline   Reply With Quote
Old 03-19-2017, 10:03 PM   #2 (permalink)
Dodge5.9's Avatar
Riding with low air pressure?
Sent from my SM-G928V using Tapatalk
Dodge5.9 is offline   Reply With Quote
Old 03-19-2017, 10:07 PM   #3 (permalink)
Greg99a's Avatar
No, I check it before I ride it.
Old 03-19-2017, 10:22 PM   #4 (permalink)
Shadow Warrior's Avatar
Welcome to the warrior family and the best warrior 4m.
I have had 3 sets of Avon so far and not ran into that issue.
I remember someone Arizona? posting a Avon tire warranty.
Old 03-19-2017, 10:27 PM   #5 (permalink)
Greg99a's Avatar
Yeah I figured I would try calling them and see what they can advise.
Old 03-19-2017, 10:29 PM   #6 (permalink)
Desertboy13's Avatar
It looks like cause of low tire pressure but I could be wrong... Good luck
Sent from my Z831 using Tapatalk
Old 03-19-2017, 10:48 PM   #7 (permalink)
Snowboy's Avatar
What's the date code on the tire ?
Snowboy is offline   Reply With Quote
Old 03-20-2017, 10:39 AM   #8 (permalink)
mkayx's Avatar
what is the production date on the tires? one side of the tire will have a longer dot number the last four are the production date. example= 4816 is the 48 week of 2016
the speed rating is right w 168mph
the load rating on that tire is 73 which is good for 805lb, that is low for me taste.
the last mc tire i had was 75 load rating for 853lb.
now that i went to the darkside the load rating id 94 for 1477lb and is xl rated so it has a reinforced sidewall
mkayx is offline   Reply With Quote
Old 03-20-2017, 05:04 PM   #9 (permalink)
Stellmon's Avatar
Weird. I've seen it happen with true sport-oriented tires after riding in cold weather, the compound on them just isn't designed for that kind of thermal shock and they split, they're designed for warmer conditions. Not sure why your Avon's would do that though if the pressure was appropriate.
We're in a horrible depression, and I gotta admit, we're starting to like it
Stellmon is offline   Reply With Quote
Old 03-20-2017, 05:19 PM   #10 (permalink)
Gilly's Avatar
I would call Avon and send pic's. They have a pretty good warranty and might replace them.
