Reaper front fender - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 03-20-2017, 03:31 PM   #1 (permalink)
Nightrider1's Avatar
Default Reaper front fender
I finally fitted my reaper front fender to my 07 R1 front end with a mix of the original R1 front fender
Nightrider1 is offline   Reply With Quote
Old 03-20-2017, 03:33 PM   #2 (permalink)
And here is a closer look
Old 03-20-2017, 03:44 PM   #3 (permalink)
Shadow Warrior's Avatar
It looks killer! also I like the gold forks.
Old 03-20-2017, 07:11 PM   #4 (permalink)
Thumbs up
Hats Off to you for finding 6-Hole 310mm rotors for the stock 3-spoke Warrior front wheel using the 6-Piston R1 Radial Calipers ... this is the 1st time I've seen this mod with the Warrior 3-spoke.
Would appreciate knowing from what mfg model & year are the wave/petal rotors @ 310mm?
Also, nice looking ride
***1187***
- Starting System
Old 03-20-2017, 08:49 PM   #5 (permalink)
Nice!
Old 03-21-2017, 09:04 AM   #6 (permalink)
Hi alanh
The discs are from a FJR 1300
Front Brake Disk Rotor YZF R7 FJR 1300 A AE AS 03-13 04 08 10 11 MT01 1670 05 06 | eBay
But you have to space the calliper out 5mm I think it was I will check
Cheers Ben.
Old 03-21-2017, 09:11 AM   #7 (permalink)
And cheers for the likes
its the best bike I ever owned to coin a phrase from the film FURY
Old 03-21-2017, 09:59 AM   #8 (permalink)
looks good nice job
Old 03-21-2017, 12:30 PM   #9 (permalink)
Hi alanh
But you have to space the caliper out 5mm I think it was I will check
Cheers Ben.
Ben thanks but no need to respond.
The rotor you used is 320 mm (6-hole) and has been used before for the 3-spoke Warrior wheel and 4-piston R1 radial caliper that uses a 6-hole 320mm rotor.
The 6-piston '07' R1 uses a 5-hole 310mm rotor which explains why you used 5mm spacers between the caliper and lower fork leg
The Later year Warriors will accommodate 5-hole rotor.
***1187***
- Starting System
