Wrap around LEDs - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 05-18-2017, 08:30 PM   #1 (permalink)
RobbSkllz's Avatar
Default Wrap around LEDs
Ok so since it's been hot for the past few days, my wraps are coming loose. What can I use to keep them adhered better and can withstand the heat?
RobbSkllz is offline   Reply With Quote
Old 05-18-2017, 08:46 PM   #2 (permalink)
Shadow Warrior's Avatar
Gorilla glue?
Not sure if it would work but popped into my head.
Old 05-18-2017, 08:47 PM   #3 (permalink)
RobbSkllz's Avatar
That crossed my mind but doesn't that glue dry up and crack?
Old 05-18-2017, 08:52 PM   #4 (permalink)
not sure have not found anything to try it out on.
Maybe some one will chime in.
Old 05-18-2017, 09:41 PM   #5 (permalink)
Used super glue on mine about 2 yrs ago. Still stickin
02 Warrior
250 Rear
Tricky Air Ride
BAK
PC5
AutoTune
BMS Bars
5000k LED
qwkwrx is online now   Reply With Quote
Old 05-19-2017, 12:02 AM   #6 (permalink)
Some of these have a tube around the led's that is loose enough to put a zip-tie through, that can be used to hold them on. You might have to take end caps off and reseal them.
Old 05-19-2017, 06:00 AM   #7 (permalink)
How about using weatherstrip adhesive? It will remain flexible for years.
g1ankarl is offline   Reply With Quote
Old 05-19-2017, 06:54 AM   #8 (permalink)
slngshott's Avatar
I used clear adhesive outdoor caulking when mine were coming loose. I taped them down for a day to let it dry. They have been good for over 2 years now.
slngshott is offline   Reply With Quote
Old 05-19-2017, 08:07 AM   #9 (permalink)
RobbSkllz's Avatar
Good ideas guys, Thanx.
Old 05-19-2017, 08:23 AM   #10 (permalink)
Use 3m double sided tape. On the new ones I make using Radiantz zflex, they have 3m double tape on the back and i now modify the end caps and put a tie wrap on the inside so they do not come loose like Rcoligan2 suggested
I would not use any permanent kind of fixative like gorilla glue as you could have a lot of trouble if you ever have to remove them. if you have tubes then use a tie wrap and new double sided tape and if they are just a stick on strip then put new 3m double sided tape on them . This stuff is used to put a lot of different parts on cars
