Speed Sensor Location - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 09-16-2006, 11:15 PM   #1 (permalink)
Default Speed Sensor Location
Exactly where is the SPEED SENSOR LOCATED?
***1187***
- Starting System
Old 09-17-2006, 12:33 AM   #2 (permalink)
Bladerunr's Avatar
Default Re: Speed Sensor Location
Just above the Tcase fill plug, you'll see a wire that goes into a lil tin cover... Just this side of the plug on top of the trans.
Old 09-17-2006, 12:42 AM   #3 (permalink)
357warrior's Avatar
Alan, is just below the rear cylinder exhaust and below the oil tank.
If you need the service manual let me know, it shows how to test it.
357warrior is offline   Reply With Quote
Old 09-17-2006, 12:51 AM   #4 (permalink)
That's the Neutral Switch [[img]/emoticons/emotion-6.gif[/img]]quote:Originally posted by Bladerunr
***1187***
- Starting System
Old 09-17-2006, 12:55 AM   #5 (permalink)
Chris...that's the Oil Temp Switch. The speed sensor has (3) wires!
I've got the manual and i still can't find the switch [[img]/emoticons/emotion-6.gif[/img]] Even checked the parts fiche and still can't find it.quote:Originally posted by 357WARRIOR
***1187***
- Starting System
Old 09-17-2006, 01:22 AM   #6 (permalink)
357warrior's Avatar
Might have to take off the side cover......If you look at page 7-7 on the manual it shows where's located, good luck[[img]/emoticons/emotion-2.gif[/img]]
Old 09-17-2006, 02:09 AM   #7 (permalink)
Bladerunr's Avatar
OOps!
I took another look... below the "oil temp switch", down in a recess, just barely visable, a three wire connector "blue white black". Looks like the whole Tcase, not just the cover might have to come off.
It's not broken is it??
Old 07-03-2014, 09:59 PM   #8 (permalink)
Originally Posted by Bladerunr View Post
OOps!
This is the neutral light switch.
Yamaha calls it the transmission sensor.
The speed sensor is just above the countershaft sprocket on the right side of the bike behind the transfer case. It could be an oil temp switch because it is mounted on a large flat plate. Not sure.
Looks like this with the trans jackshaft in place.
Roadstar B is offline   Reply With Quote
Old 07-03-2014, 11:22 PM   #9 (permalink)
NOTE: Do you realize that this post Ended 09-17-2006
____________________________________
THIS IS THE SPEED SENSOR .... It is perpendicular to the trans output shaft to count teeth and that you can take to the Bank. HAS THREE WIRES
_______________________________________
THIS IS THE NEUTRAL SWITCH AND HAS ONE WIRE AND THAT YOU CAN TAKE TO THE BANK
________________________________________
THIS IS ALSO THE NEUTRAL SWITCH
***1187***
- Starting System
Last edited by alanh; 07-04-2014 at 12:03 PM. Reason: added: Note of post date 09-17-2006
Old 07-05-2014, 02:16 AM   #10 (permalink)
Thanks for that explanation. I appreciate your time Alanh.
