V bak questions - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 08-30-2007, 03:47 PM   #1 (permalink)
bnpain's Avatar
Default V bak questions
Hey guys what would cause a lack of throttle response after installing Woody's v bak? I followed the instructions to the letter but seems I have to grip more throttle than before install, Anyone notice this? I installed a speedstar exhaust and added the vbak after noticing a lack of power, probably due to too much air so bumped the ecu to +2 to compensate (was set at -6 each) I have an 06 and the only mods I have is the speed* and v bak planning on pcIII next season, any ideas?
Thanks
bnpain is offline   Reply With Quote
Old 08-30-2007, 04:13 PM   #2 (permalink)
dhousedog's Avatar
Default Re: V bak questions
Check your plugs. Chances are that you are still running lean.
dhousedog is offline   Reply With Quote
Old 08-30-2007, 04:22 PM   #3 (permalink)
I have only the VBAK and I bumped the air/fuel +3 on both cylinders. Plugs look perfect. Don't know if that's causing your problem, but sounds like you're running awfully lean. VBAK + Exhaust and you should bump it even more.
Have you checked your spark plugs? Here's a chart for reference:
http://www.verrill.com/moto/sellingguide/sparkplugs/plugcolorchart.htm
Pyre is offline   Reply With Quote
Old 08-30-2007, 04:26 PM   #4 (permalink)
tostyj's Avatar
Pyre, thanks for posting that chart! Great resource.
tostyj is offline   Reply With Quote
Old 08-30-2007, 04:30 PM   #5 (permalink)
Churchkey's Avatar
Replied to your PM, its still lean, start with the CO # that we talked about.
Forum member #113
Brother of the Wind
Old 08-30-2007, 08:42 PM   #6 (permalink)
bnpain's Avatar
Thanks guys consensus lean, will bump it up tomorrow
Old 08-31-2007, 12:37 PM   #7 (permalink)
bnpain's Avatar
Hey guys thanks for the tip, bumped it up to +6 throttle returning. Going for a ride tomorrow will check plugs and maybe bump some more.
