31t pulley - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 10-26-2007, 11:08 PM   #1 (permalink)
roadierider's Avatar
Default 31t pulley
I'm installing a 31 t pulley on my son's warrior tomorrow {hitmann123} I was wondering since the new pulley will be wider then the stock 32 since it fits all roadies from 99 up, will the belt track in the middle or toward the front edge of the pulley when properly aligned? the only one I've done is on my 02 silverado with the wider belt. also about how much will the speedo be off by? I have a speedo healer on my roadie. Thanks guys!!
roadierider is offline   Reply With Quote
Old 10-27-2007, 12:34 AM   #2 (permalink)
rider510's Avatar
Default Re: 31t pulley
What is speedo healer do? I've noticed on my Warrior that my speedometer is off. Does it correct for inaccuracies in the speedometer? Does it effect the odometer? I'm wondering if my speedometer being off is causing my odometer to rack up the miles faster than it is supposed to. I'm sorry I don't know the answer to the pulley question you have asked as I have just recently purchased my bike.
rider510 is offline   Reply With Quote
Old 10-27-2007, 05:37 AM   #3 (permalink)
if your speedo is registering faster then you are actually going it will also show more miles on the odo. the speedo healer re calibrates the speedo but you need to know how much you are off by before you can recalibrate it
Old 10-27-2007, 09:03 AM   #4 (permalink)
bnpain's Avatar
I thought that the 31t is the same width as stock 32t, someone confirm please I just received mine today.
bnpain is offline   Reply With Quote
Old 10-27-2007, 10:51 AM   #5 (permalink)
darkstar's Avatar
It will track to the inside of the front pulley.
darkstar is offline   Reply With Quote
Old 10-27-2007, 10:27 PM   #6 (permalink)
fella5's Avatar
It is wider than the stock maybe because it doesn't have the inside lip as the stock one does. The 31T should track to the inside as long as everything is stock.
fella5 is offline   Reply With Quote
Old 10-27-2007, 11:24 PM   #7 (permalink)
getsumbaby's Avatar
So - the 31t pulley will raise rpm's? What comes stock on an '03? I would like to lower my rpm's a little. Is it possible without going into the trans?
getsumbaby is offline   Reply With Quote
Old 10-27-2007, 11:32 PM   #8 (permalink)
rdarnitall's Avatar
All Warriors come stock with a 32T pulley. You can go to a 33T (which is stock for the RoadStar), to lower your rpms a couple hundred. You lose a little bit of low end "umph" though.
Turning dinosaurs into noise, 4 gallons at a time!
rdarnitall is offline   Reply With Quote
Old 10-28-2007, 02:29 AM   #9 (permalink)
getsumbaby's Avatar
Is that a simple bolt on? And will the stock belt work?
Thanks,
Ed
Old 10-28-2007, 08:12 AM   #10 (permalink)
Churchkey's Avatar
An aftermarket single lip wide pulley should be a bolt on. If its a Yamaha 31 tooth pulley that has the bolt on inside flange check that it does not rub on the inside of the case. When I used the Yamaha pulley I had to unbolt the inner ring & grind the lip for clearance.
Forum member #113
Brother of the Wind
