New Akitadog Coil Relocation plate for Dyna Coils, VBAK - Page 3 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 08-23-2011, 09:34 PM   #21 (permalink)
The stock airbox has the intake air temp sensor located at the frt RH side of the box where there is zero air flow and possibly less turbulence which is better for Saturation. You are not trying to cool the sensor
***1187***
- Starting System
Old 08-24-2011, 04:23 AM   #22 (permalink)
somedude451's Avatar
Originally Posted by Loren78 View Post
One more thing. . . Send me one gratis and I'll try to work up an "accessory" FPR mount that allows stock high pressure line and short extension of low pressure line, and send you pix for fab.
Incorporating the FPR into the plate, or at least the option, sounds like the perfect solution. Gave that any thought?
somedude451 is offline   Reply With Quote
Old 02-26-2015, 05:33 PM   #23 (permalink)
soon2have1's Avatar
Where can I get one of these plates and how much are they thank you ? I bought a set of dc2-1 coils and have been reading up a lot on installing them thank you for your help
soon2have1 is offline   Reply With Quote
Old 02-26-2015, 05:50 PM   #24 (permalink)
newwarorder's Avatar
If Akitadog doesn't respond to you based on this thread reply, send him a PM and he will tell you how to get one from him. Akitadog is his forum name.
"If in doubt, throttle out!"
newwarorder is offline   Reply With Quote
Old 10-21-2015, 05:49 PM   #25 (permalink)
260warrior's Avatar
Akitadog, are you still offering these relocation plates? If so please pm me to set something up.
260warrior is offline   Reply With Quote
Old 10-22-2015, 01:04 PM   #26 (permalink)
akitadog's Avatar
Send a message via Yahoo to akitadog
260Warrior check your PM...
Mark
Contact:
akitadog is offline   Reply With Quote
Old 04-21-2017, 06:59 AM   #27 (permalink)
OK how do I get in touch with the Akita member about buying a plate.
Quedog in VA.
Quedog378 is offline   Reply With Quote
Old 04-21-2017, 09:02 AM   #28 (permalink)
Quedog in VA.
Click the member right above your post and send him a PM.
2008 Midnight Warrior.
-Speedstar HC pistons
-VBAK
-V&H Big Shots
-PCV w/autotune
onebaddz is offline   Reply With Quote
