Trouble Starting - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 02-18-2012, 09:20 PM   #11 (permalink)
iowawarrior's Avatar
you don't list what year your bike is. put some cables on it {from a car or battery charger/starter} and see if it starts. if it does, buy a battery. problem solved. and let us know.
Old 02-18-2012, 09:26 PM   #12 (permalink)
If you do try this, DON'T have the car running.
Oh wait, he's suggesting using a car battery charger.
Well, you can jump start it from another 12 volt battery, just don't have it running...
Old 02-19-2012, 08:33 PM   #13 (permalink)
actually, i was talking about a car battery OR a charger. i don't know if it really matters if the car is running or not. i know there has been enough posted about it both ways. but there should be no need to have the car running. if you have a low battery and you hook it up to another battery, it should start right up. so, yeah, err on the side of caution.
Old 02-20-2012, 01:31 AM   #14 (permalink)
Most views are to never start a car with a motorcycle attached to the car battery.
Old 02-20-2012, 08:58 AM   #15 (permalink)
sanny651's Avatar
You never want to jump start a bike/ATV off a running car or truck. You chances of ruining your voltage regulator are through the roof. I learned the hard way on a Shadow I had. I've had countless people on an ATV site I'm on try and and 9 out of 10 times they say now their battery won't charge....the culprit, bum voltage regulator.
Bottom line, don't. You don't even NEED to have a car or truck running as the battery in them is so substantially larger than that of a cycle or ATV, that the need to have the alternator run to maintain the voltage during the jump start is negated. All risk, no reward by having the car running.
sanny651 is offline   Reply With Quote
