Install exhaust Vance and Hines - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 06-16-2012, 01:19 AM   #1 (permalink)
Default Install exhaust Vance and Hines
Now my rear brakes are staying applied. I am not sure why but the rotor started to glow and the fluid was like boiling...help
Sent from my SAMSUNG-SGH-I777 using Motorcycle.com Free App
d1byess is offline   Reply With Quote
Old 06-16-2012, 02:23 AM   #2 (permalink)
sangathor's Avatar
Make sure your rear brake clears the front of the header pipe. It may seem like there's space between them but when the pipe gets hot it expands a little and can be making your pads drag on the rotors while you are moving. Adjust your brake lever for more clearance before you burst into flames.
sangathor is offline   Reply With Quote
Old 06-16-2012, 02:26 AM   #3 (permalink)
I take it you mean the rear first chech to make sure that no part of pipe or heat shields are touching the rear brake pedal or the long push rod for the rear master cylinder
Sent from my SGH-T499 using Motorcycle.com App
Old 06-16-2012, 02:27 AM   #4 (permalink)
You beat me to it
Old 06-16-2012, 01:42 PM   #5 (permalink)
I think that was the problem. Thanks for the help
