#22 (permalink) | |
I have read the same. The tip is very fragile. I know you avoid the old "coin" style gappers and do not pry against the iridium. I understand it can be done with care and the proper tool.
Sent from my iPhone using MO Free |
#23 (permalink) | |
Being RSWarrior-specific, iridium plugs have some other great advantages. The difference in resistance is very very small in spark plug applications and there isn't much spark lost to heat. Plus there's less room for carbon deposits on the small tips which is why they are shown to be better at self-cleaning and why fouling is less common with iridium. I don't miss copper spark plugs at all, the tips get hot and the round-out effectively opening the spark gap wider rtequiring regapping and there's other down-sides to the older technologies. All spark plugs are built better than every before, so its hard to go wrong wit anything these days. I've read all the same stuff, including platinum, and all I can say is I'm very happy with the iridiums and I have zero maintenance issues even with the hotter dyna coils.
![]() My Pics Great Members Popular Mods Model Year Differences Group Rides WyomingDIY KyleNV Technical Last edited by arizonawarrior; 08-28-2012 at 01:18 PM. |
#24 (permalink) | |
I'm new to this EFI stuff. Being that the Warrior is not a closed loop EFI system, is it a safe assumption that because the resistance difference is so small and the combustion efficiency difference is not very much, will the EFI adjust accordingly for that difference? Stupid question for most I'm sure, but I'm a carb guy and if there are adjustments needed, you manually need to make the change (as you all know). Good conversation with excellent points gang. Keep 'em coming! Great stuff to chew on.
#25 (permalink) |
The EFI doesn't have a way to adjust for that but it doesn't really have an effect.
#26 (permalink) |
Sure copper and sliver are better conductors than iridium. It don't mean doosquat at the voltage we are talking about. 35,000 - 50,000 volts it is all about sharp and pointy.Dyna coils need more plug gap B/C they make higer voltage. It is like your garder hose turned on full the water might leave the end 5 inches but put your finger over the end and it will shoot 20 ft. across the yard.U can gap Iridium's,just be careful. put .003 to .005 more gap in them and reinstall and let see what the A/F meter tells us.
#28 (permalink) | |
I run a tighter gap on iridiums than factory because of the dyna coils. Everyone on this site that runs dyna coils runs a tighter gap, I know that because that's where I got my info from.
You can gap any spark plug, just use the right tool.
#30 (permalink) |
Manual says every 8,000 miles for plug changes from what I heard. I haven't looked it up, but someone said that.
I guess I don't understand the gapping stuff. I would think that gapping them closer would require less power, and when you have a coil that puts out more power than stock you'd want to gap them larger. I'm not saying that's right...I'm saying that's what I would think in my head. Can someone explain the reason why I am wrong?
