Downshifting wearing out clutch - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 09-14-2012, 02:28 PM   #1 (permalink)
robriguez's Avatar
Default Downshifting wearing out clutch
I'm starting to feel a bit of clutch slip when accelerating hard (WOT). When the tach hits the power band around 3k-3.5k is when I notice it in 4th and 5th only. While riding normally I do not notice it at all.
Over the summer I've been downshifting more and more. Love the feel, love the sound, love the ability to instantly accelerate again if i need to, just plain fun. Now, having done so for about 3k miles, I think its causing additional wear on my clutch.
I have about 17k on the clock so far, when does the clutch typically need to be replaced? Is this normal?
Old 09-14-2012, 02:33 PM   #2 (permalink)
Mike7202's Avatar
do you have the barnetts upgrade? if not then get it. that will more than likely fix your prob
Mike7202 is online now   Reply With Quote
Old 09-14-2012, 02:35 PM   #3 (permalink)
skybejef's Avatar
I am at the same miles you are and have down shifted the whole time I have had the bike and no slipping yet. I also go to the drag strip and at times ride the wheels off it with no clutch issues. What clutch spring are you running? I know the early Barnett spring requires some maching done or clutches do start to slip early.
skybejef is offline   Reply With Quote
Old 09-14-2012, 02:48 PM   #4 (permalink)
robriguez's Avatar
clutch is 100% stock original from factory.
Old 09-14-2012, 03:12 PM   #5 (permalink)
Zalama's Avatar
I noticed some clutch slipping few weeks back. I have about 43 500 miles on right now.
I was planning to had the clutch opend up next spring. I would think that the clutch should at least last that 45 000 miles or so.. imo.
Northern star alliance is born.
Zalama is offline   Reply With Quote
Old 09-14-2012, 03:37 PM   #6 (permalink)
Bladerunr's Avatar
They all get slippy around 20k, yours might be a lil early. Mind telling us what kind of oil you run.
And
As others have said... Get the Barnett.
Old 09-14-2012, 03:50 PM   #7 (permalink)
robriguez's Avatar
mobile1 synth car oil.
Old 09-14-2012, 04:25 PM   #8 (permalink)
BOSSMAN2677's Avatar
Mines starting to do the same in 4th and 5th WOT, but I do have 50,000 miles on the stock clutch. I have always used the gears to slow me down. Guess its time for the Barnett!
BOSSMAN2677 is offline   Reply With Quote
Old 09-14-2012, 09:23 PM   #9 (permalink)
Send a message via ICQ to bigr
I always thought that using the car oil is a big no no because of the wet clutch on the bike. Something about the friction modifiers I think. Don't want to start a which oil to use war, but maybe that is your problem.
bigr is offline   Reply With Quote
Old 09-14-2012, 10:50 PM   #10 (permalink)
parkinglot's Avatar
Rob, mine was slipping a bit at WOT in higher gears..I adjusted the clutch and changed the oil and it has gone away. I don't have the mileage you do, but it isn't slipping now..I need to do the barnetts..maybe this winter..
Drivin my life away...
