bike will not shift gears - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 09-14-2012, 07:00 PM   #1 (permalink)
weil0127's Avatar
Default bike will not shift gears
I was comming home from work the other night and my clutch cable broke. I just got the new one and put it on, but I cant get the clutch to engage. It seem like the lever is isn't going as far as it should and getting stuck. Please somone help me out.
weil0127 is offline   Reply With Quote
Old 09-14-2012, 07:05 PM   #2 (permalink)
be sure cable is correctly routed in cable holder near crankcase. mine was stuck behind cable holder when i bought bike.
Old 09-14-2012, 07:30 PM   #3 (permalink)
If you are sure you have the correct cable, then notice the cable has a middle adjustment area plus the lever adjustment area. If you have a service manual I think it has a write-up for installing a NEW cable that includes setting the middle adjustment first and then fine-tuning with the lever adjustment. Also be sure both of the cable ends are are fully seated.
Old 09-14-2012, 08:30 PM   #4 (permalink)
weil0127's Avatar
The cable is correctly routed. I don't think the cable is the problem. Its like the clutch lever isn't moving as far as it should. If I take the cover off to look at it will the oil comes out from the cover?
Old 09-14-2012, 08:41 PM   #5 (permalink)
No, do not pull any cover off. Just be sure cable is attached correctly.
Also be sure it moves the lever at the bottom of the cable as much as possible. Pic is in service manual.
Old 09-14-2012, 09:01 PM   #6 (permalink)
weil0127's Avatar
I started the bike in neutral and pulled the clutch all the way. Then tried to put it in gear and it jurked forward with the clutch pulled all the way and died. The feel of the clutch is very light too.
Old 09-14-2012, 09:27 PM   #7 (permalink)
That sounds like clutch is not fully disengaging,can you post a pic of the lever on the case. Maybe it has moved. I lost the bolt on mine and didn't notice.
The DarkMidKnightWarrior
Old 09-14-2012, 11:03 PM   #8 (permalink)
Arkansas Warrior's Avatar
I agree - Sounds like cable is not adjusted or the lever on case
has slipped.
Can you move the lever on case by hand?
Frak it! I feel better now
Arkansas Warrior is offline   Reply With Quote
Old 09-15-2012, 08:30 AM   #9 (permalink)
iowawarrior's Avatar
clearly, it's the wrong cable or it's not hooked up right or something has slipped. did you remove the lever on the case when changing the cable? can you post the part number of the cable? plus 1 on all of the above.
iowawarrior is online now   Reply With Quote
Old 09-15-2012, 11:05 AM   #10 (permalink)
madtom421's Avatar
Do you still have the broken cable? Maybe compare the two see if their the same length etc. When I installed my sr-2 It took me a full day of minor adjusting to the cable in order to get the tranny to shift smoothly.
Ah, well; Who wants to live forever hahaha....DIVE!!!!!!!!
madtom421 is online now   Reply With Quote
