10yrs old and she wants to show her age... - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 10-12-2012, 10:49 PM   #11 (permalink)
sactobuc's Avatar
Originally Posted by BiggG View Post
2002 = 11 years old........
have you done any mods lately or had the fuel tank off for some reason ????
No mods, and recently replaced the fuel joint, however it was doing this before the fuel joint replacement..
sactobuc is offline   Reply With Quote
Old 10-12-2012, 10:50 PM   #12 (permalink)
sactobuc's Avatar
Originally Posted by 1256day View Post
Common problem.
Check the little coil wires, re crimp them, be careful
Also check lean angle sensor, side stand, rectifier wires. Put a little dab of dielectric grease on the connectios.
Also make sure your cps recall was done.
I also like to check the tank vent lines too
Sounds good, and thanks.... this is what weekends are for...lots of tinkering.
Old 10-12-2012, 10:51 PM   #13 (permalink)
sactobuc's Avatar
What visual clues to you see when it happens? For example, when it cuts out do the gauge lights go out or does the tach sweep as if you just turned the key on? Also, does it happen only when riding between 75-85mph or was that just an example speed?
Not sure of any visuals, but none that come to mind stood out when I looked down at the meters... and that was just a sample speed thanks...
Old 10-12-2012, 10:53 PM   #14 (permalink)
sactobuc's Avatar
Originally Posted by 4seeaye View Post
It is your lean angle sensor. Search for thread "loss of throttle response". Page two I describe the fix and voila. Same thing happened to my 02. I will go out on a limb and guarantee this will fix the problem. 15 minute fix with a dab of superglue. 0 dollars. Or replace LAS. How To: Disable Lean Angle Sensor (07-08) R1 - Yamaha Forum : Your Yamaha Motor Products Community & Resource
When the LAS shuts-off the fuel I was thinking the rpm falls to zero?
[Added: srwarrior, see manual page 1-16 to follow what we're talking about]
It does not fall to zero. With his current miles I would almost guarantee the Lean Angle Sensor if all recalls have been done. The Lean Angle Sensor is behind your horn at the front pulley. Pop the horn off. Remove the nut holding the bracket for the LAS. Break down the LAS. And put the tiniest dab of super glue on one of the pivot arms to hold it in place. The pendulum will not swing now. Reassemble and go for a cruise. If problem is solved then you can make the decision to replace or leave it be. This is a ten minute operation. If you search for LAS in the forum you will find a thread with a link to an R1 forum with great pics of the switch. I went nuts trying to figure this problem out and the fix is truly simple. Try this first. If the problem persists you can go back in the LAS and break the dab of super glue so your switch works normally. The tiniest dab is key. You can check my thread "please help diagnose" to verify symptoms.
The symptom of being able to shift and the throttle come back to life is the key telltale for the LAS problem. As well the speed it occurs. Identical to my initial symptoms. I think as the pivot arms wear a bit and the harmonics the warrior produces at around that speed the sensor pulls back away from the sensor pickups tricks the sensor into thinking the bike is tipped when actually it is shifting towards the rear of the bike.
This sounds like you have really researched this problem, so I'mma start there and post back after I've had the chance to do so. Thanks for posting, and I sure hope this cures her ills.
Old 10-12-2012, 10:55 PM   #15 (permalink)
sactobuc's Avatar
Originally Posted by Reese91 View Post
Ok, I have a couple of questions which might help / be irrelevent to your current issue. when your bike is not in neutral is the neutral light illuminated? if so does it go off / on at any point outside of neutral?
I ask because my light was on and my bike quit on me at 90 mph on the road and it turned out it was the freaking relay going out....got to push my warrior turned paper weight uphill because of it.
here is a link to my thread if you are interested in my trouble shooting ect.
2002 warrior won't start after quitting in middle of road
if this sounds like your issue you might want to order the part I did and see if it fixes it, its a whole lot easier than pushing the bike up hill / having it die on the highway at rush hour.
best of luck and let us all know what the problem finally turned out to be.
Never had the neutral light come on outside of neutral.... and I sure as **** don't want to get caught pushing a Warrior paper weight. thanks and I'll keep y'all updated.
Old 10-13-2012, 03:56 AM   #16 (permalink)
4seeaye's Avatar
Note in the thread loss of throttle response all the typical CPS, battery, coil suggestions were there but the fix for him as well as myself was the LAS. The symptoms are just spot on for your prob. I remember just hamering down the highway at about 85 on the speedo and she just cut out. All electrics going just zero throttle response. I would downshift and bang instantly back to life. Didn't make any sense. I ignored it for a while because the shift "fix" still allowed me to ride. Problem is it will start to happen more frequently and in lower gears at lower speeds. Not the confidence booster you need when you want to hit that gap or merge or you're hot rodding it with a buddy and your bike is cutting out. It is a very easy fix. Good luck.
4seeaye is offline   Reply With Quote
Old 10-13-2012, 05:14 AM   #17 (permalink)
I have to admit I do like 4's LAS diagnosis and fix and remember when he 1st posted it.
I had the exact same thing happen, rolling down the highway at 85 and then dead engine.
I thought for sure it was the CPS, Flip the kill switch, drop the clutch, engine came back to life.
I was in a panic, cause I was leaving for a 3000 mile ride in 2 days.
The 4m came to the rescue with the suggestions I posted.
I'm not sure which one fixed it, cause I did them all, at night with a flash light in a dirt parking lot.
I did notice the 4 little coil wires were not snug on the coils and I think that was the real culprit, but again I am not positive. Be carefull with those tabs they bend very easy.
Group Rides
Old 10-14-2012, 08:45 PM   #18 (permalink)
Proceedbob's Avatar
Common problem.
This is the answer you seek. Pull the tank and remove the two spade connections from the coils and give them a little squeeze with some pliers until they go back on with some resistance.
Proceedbob is offline   Reply With Quote
Old 11-13-2012, 10:13 PM   #19 (permalink)
4seeaye's Avatar
FYI it was his LAS.
Old 11-14-2012, 02:46 AM   #20 (permalink)
jarv's Avatar
Have you heard for sure?
