#21 (permalink) | |
#22 (permalink) | |
You'll need to unplug the ECU and be aware that the (2) Red/Black wires in the LCV plug are LIVE with the key off so disconnect the battery terminal or pull the 10A Fuse #70 that powers the positive polarity of this device. If you read my earlier contribution, LCV 101, it clearly states that the valve is sequenced by negative polarity via the ECU/cpu driver in a sequencial fashion and that's the reason why Pins 21-22 & 43-44 are opposite each other on the ECU plug. These outputs are triggered by solid state switches and possibly one of the wires is broken or poor contact. Being that the LCV is a stepping motor, imo, it would be a crap shoot testing the resistance of the wires because the motor poles aren't in alignment but i've been wrong before.
In my signature is a link to a comprehensive wiring diagram and ecu pin-outs Last edited by alanh; 11-05-2012 at 10:15 PM. |
#23 (permalink) |
For those following this thread i have validated and checked the following from days gone bye and haven't thought to share this info until now
