#11 (permalink) |
Ding, ding, ding!!! I bet that's where your issue is. Were you able to isolate the bars completely? I realize the bars are separate from the ground circuit, via the rubber mounts in the triple tree, but if you had multiple chaffed wires in the bars, or the clutch cable was providing a ground path for a single chaffed wire...might be something to consider.
#12 (permalink) | |
I recall a post not all that long ago, that i responded to, that was exactly this issue with turn signals going dim each and every time the OP touched the clutch lever the cable barrel provided a path to GRND ![]() ___________________________ Duane ... i just uploaded a new Warrior wiring diagram just for your model year Last edited by alanh; 11-25-2012 at 01:46 PM. |
#13 (permalink) |
I agree with yall about the bars and they are internally wired. I have kept that consideration in mind. We took the headlight apart Sat and unplugged all but 2 (Kill and starter) switches, that are going into the bars. Still blows. I'm not ruling out bars, could certainly be there, and prob next step will be to to remove and check, not much fun there! LOL It would be much better if It were a hard ground so I could see with a VOM, instead only coming in at 2500 rpm!!!!!!! Kinda hard to find..................
If you can get it to sit still.....Paint It![]()
#15 (permalink) | ||
You can rule out all these wires by isolating them as previously discussed and marked above in RED. You only need to deal with these wires and nothing more. Make sure that the Brown wire is not grounded for the tach & speedo from the main harness within the headlight housing. If you continue to blow a fuse with the above procedure the problem is else where so don't waste your time. Move on to the other component harnesses which might involve unwrapping those or the main harness. |
#16 (permalink) |
Alan, Thanks, My son is also following this thread so he may get a chance to start checking at home. This certainly sounds like it could be the prob, but if so, It should not be in the internal bar wiring. We had that all unplugged in headlight this weekend and fuse still blew, BUT I will recheck!!!! Should not be a prob running these down. Horns have been unplugged, but could certainly be in the wiring as could all your other suggestions! Thanks for all the time you have put into this Alan! And I have wondered about that flasher, you watch, that's prob gonna be it!!!!
#17 (permalink) |
Well, as always, Alan pointed me in the right direction. I traced the Brown wire from fuse panel towards front of bike. It was fused in numerous places on the main run all the way to where 1 brown splits into 4. I replaced this wire up to where it splits into 4 brown wires and one Black w/white stripe(?) . Figured I had it whipped, but fuse still blew. Black going to horn, cut it out, now all good. Rear horn works, but front doesn't for now. However, front horn intermitantly comes on very low untill I unhooked it, without horn button pushed, just key on. If I'm not mistaken, horn is hot, and button completes ckt to ground??? That would explain it,so I still a high resistance short in that leg. Thanks Alan, for all your assistance and guidence!
#18 (permalink) |
That's wild glad you found it. The solid black is the 'ground side' of the front horn which later merges with the solid pink wire that goes to the horn switch. Yep the power exists to that point and pressing the horn button completes the circuit, so if the solid black wire was vibrating and shorting to metal then you found it. Did the horn relocate have much to do with it? Also, do you think all this time there might have been a momentary but possibly weak horn-sound at the moment it shorted to ground at ~2500 rpm but the motor noise masked it? Just wondering for the future!
![]() My Pics Great Members Popular Mods Model Year Differences Group Rides WyomingDIY KyleNV Technical Last edited by arizonawarrior; 01-21-2013 at 12:54 AM. |
#19 (permalink) | |
![]() I suspect that's a typo above and should read B/W (black/white) but i've been wrong before
#20 (permalink) | |
... though i suspect that Duane's RH horn might have a dead short now but that's a crapshoot!I believe Duane cut the B/W (black/white) wire which is probably fused to the rear brake light sw brown wire as i suspect they physically run side by side. Now if the horn has a dead short it would see Grnd and would explain why he had to physically unplug the horn. |
