pc111 Question - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-05-2012, 06:57 PM   #1 (permalink)
dewie45's Avatar
Default pc111 Question
Just wanted to know if pc111 usb maps work on plain pc111?
dewie45 is offline   Reply With Quote
Old 11-06-2012, 01:10 AM   #2 (permalink)
You cannot automatically demote a PC3USB's .djm into a .map file for the PC3-Serial. However you can use COPY/PASTE to copy from the .djm and Paste to the .map file BUT its a good idea to start with an empty .map file that has not been used before. See the .map files that come with the PC3-Serial or get them from the power commander website, and you'll see that one of the first files is named M304-000.map. Copy it to another directory, rename it something.map so (to avoid over-writing the pristine empty file). Paste the data from the .djm into your new .map file and save it.
Remember to save a copy of the .map file currently on your PC3-Serial onto your hard drive BEFORE you send the new .map file to the PC3-Serial because the new file will over-write the existing file.
There's more info in the power commander software's HELP file (click on the HELP menu item and select manual - if your software doesn't have the manual there then go to the Documentation Forum and look at the Fuel Managers thread for a pdf attachment of the PC3-Serial help file).
