converting a warrior engine from EFI to carb?s. - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-12-2012, 07:53 AM   #1 (permalink)
Default converting a warrior engine from EFI to carb?s.
anyone know anything about coverting from efi to carb? anyone done it?? tips? advise? general ideal? haha? thanks.
Mitchell Tannahill
mitchell tannahill is offline   Reply With Quote
Old 11-12-2012, 08:08 AM   #2 (permalink)
twicechosen's Avatar
OK I'll bite. Why would you want to do that? I love the performance I have now and don't want to mess with the raw power the EFI gives me; but hey that's just me. What say ye sir?
Stay in the word!
Member 24379
Old 11-12-2012, 08:16 AM   #3 (permalink)
You have to make your own intake manifold, which i see in your website you have a tig and the knowledge to do it. From what i have found out on this forum you just have to unplug the fuel injectors and you can use the rest of the wiring on the bike for it to work. I was going to try it myself on down the road. I replaced my intake manifolds because the rubber that is attached to the intakes were dry rotted and leaked, so i have the old intakes to use for making a intake for the carb. Also Patrick racing i think could give you some information on making the change. I will follow this thread to see what you come up with.
Old 11-12-2012, 09:12 AM   #4 (permalink)
Jbat's Avatar
why do it? dont like EFI? want to clean up the harness for a custom job? your not gonna pull more ponies so for me its a waste
Old 11-12-2012, 12:54 PM   #5 (permalink)
I'm thinking you're asking about this because on your custom job you're not sure what's involved in putting in a fuel pump.
I'd think installing a fuel pump will be easier than switching to carbs.
Old 11-12-2012, 01:37 PM   #6 (permalink)
MRMAXXX's Avatar
Patrick Racing used carbs on there race bikes when they were racing in Prostar. So I would call them up, I'm sure they can cut through all the BS.
Bob
MRMAXXX is offline   Reply With Quote
Old 11-12-2012, 08:51 PM   #7 (permalink)
mr_noize2's Avatar
Someone did it for a supercharger years ago, but they never got it to work well.
mr_noize2 is offline   Reply With Quote
Old 11-12-2012, 09:01 PM   #8 (permalink)
thanks for the advise so far guys. yes, the reason behind it is because its a custom job, needs to be super neat and clean, i also posted about an aftermarket, inline fuel pump that will supply the correct amount of pressure, im just looking at all of my options before i start buying parts.
Old 11-13-2012, 09:45 AM   #9 (permalink)
Actually, our bike does make more hp with a carb set-up.
Reliable? Maybe, maybe not. I don't know as I do not have it. But I have seen the numbers from other warriors that went carb and they were a bit higher than our usual numbers.
Originally Posted by rx_warrior View Post
That is the cleanest, most pure interpretation of the Midnight I have ever seen in the last 6 years!
Warrior Brothers World Map
Old 11-13-2012, 02:05 PM   #10 (permalink)
Does the bike make more power carbed or is it just the rev limiter being gone? PR posted here once that the max rpm they could put thru the motor was 7,000 rpm and shortly after that the motor failed. They must have found a way to rev-limit it so the carbed motor would last long enough to cross the finish line. The bikes needed a lot of TLC but I don't know how much of that was due to the carb mod.
Does anyone remember the best numbers posted in official races by PR's carbed bikes and by their one injected and ECU'd bike? They were both monster numbers.
