HID install - need help - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-15-2012, 10:09 PM   #11 (permalink)
kayak101's Avatar
What kit did you use, Leader?
EDIT - nevermind I found it.
03 Warrior
Old 11-15-2012, 10:13 PM   #12 (permalink)
You should contact sharp.
Old 11-15-2012, 10:16 PM   #13 (permalink)
kayak101's Avatar
I plan to. I've left them a voicemail and sent them an email. Hope to get in touch with them tomorrow. Thanks
03 Warrior
Old 11-16-2012, 08:31 PM   #14 (permalink)
burnchassis's Avatar
Originally Posted by kayak101 View Post
OK so pic 1 is the entire kit. Pic 2 is the kit put together. Pic 3 is 2 connections I don't know what to do with.
pic 3 = the larger plastic plug with the yellow end goes to your ballast...the 3 prong metal end plugs into your existing h4 socket you take out your old bulb,and plug in that 3 prong in its place...plug the other end into a ballast ,and ground the ground loops.
does that help?
your complete kit #1 pic shows a car harness..a dual headlight setup The "new" thing is a splice of some sort. just be sure you're using all from the same side..if you just use 1 side,you'll be ok ,and you can tuck the other side...in case you want to add another light ...or cut it off like i did. I just used the car harness because it's longer,and I happen to have a couple.
-CS
burnchassis is offline   Reply With Quote
Old 11-16-2012, 10:45 PM   #15 (permalink)
MikeOlmt's Avatar
Exactly!!!
That wiring harness is for a car, or a bike with two HID's. It's meant to plug into a second ballast, and second bulb for highbeam control.
Just cut them, or use the longer side if it works out better that way, and tuck the short side out of sight.
Good luck!!
Old 11-16-2012, 11:22 PM   #16 (permalink)
kayak101's Avatar
Thanks. I'll try this tomorrow morning. What I got back in an email from SharpHID:
If using a single bulb with a hi/lo kit you will end up with a few connectors that aren't used
03 Warrior
Old 11-16-2012, 11:42 PM   #17 (permalink)
kayak101's Avatar
So technically the way i had it hooked up the light should either work on hi our low beam, correct? I had everything hooked up, just not to the connector on the far end.
Sent from my DROID RAZR using Motorcycle.com App
03 Warrior
Old 11-17-2012, 11:28 AM   #18 (permalink)
kayak101's Avatar
Thanks so much guys. I got it tested this morning. All I have to do now is route all the wiring. Holy crap it's bright.
03 Warrior
Old 11-17-2012, 12:18 PM   #19 (permalink)
That's cool, but I thought you said it didn't work before?
Old 11-18-2012, 06:22 AM   #20 (permalink)
Thumbs up
Sweet!
-CS
