Dynacoil insCatall question - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-17-2012, 06:32 PM   #1 (permalink)
kayak101's Avatar
Default Dynacoil insCatall question
I have the akitadog plate and want to switch over to my dynacoils. What do I do with the connections here in the photo that are on the stock coils? Thanks
03 Warrior
Old 11-17-2012, 07:12 PM   #2 (permalink)
Cut them off and crimp on the supplied new eyelets. Install newly crimped eyelets to the dyna coils with the supplied screws and lock washers and enjoy .
Originally Posted by rx_warrior View Post
That is the cleanest, most pure interpretation of the Midnight I have ever seen in the last 6 years!
Warrior Brothers World Map
Old 11-17-2012, 07:40 PM   #3 (permalink)
californiacruiser's Avatar
Just a heads up, unless that is the later model Akitadog plate you won't have enough clearance for the coils or the terminals. You can cut it with a jigsaw if its the earlier plate or get the new one made for the Dynacoils from him.
Albert Einstein
Member #3,925. Woo Hoo!!
Old 11-17-2012, 07:58 PM   #4 (permalink)
kayak101's Avatar
The one I have is made for dynacoils. I have his old plate when I did the coil relocation.
Midnight - question...when I put the new crimp connectors on, do they get attached to the mounting holes? I don't see any other place to attach them...
03 Warrior
Old 11-17-2012, 08:10 PM   #5 (permalink)
On the top of the coil are two brass threaded holes. These are the holes for those wires....
One of your wires is ground to both coils, best to use the same hole on both coils for (-) and the same on both for (+)
If you cant see them, I can take a picture of mine for you....
If you have a soldering iron, I like to flux and solder ALL my crimps for a sure connection...
Old 11-17-2012, 08:19 PM   #6 (permalink)
See:
Old 11-17-2012, 08:26 PM   #7 (permalink)
kayak101's Avatar
Thanks, scawein
03 Warrior
Old 11-17-2012, 08:49 PM   #8 (permalink)
NJWarrior's Avatar
Hopefully someone will confirm but if I remember correctly the terminal at the wires gets cut and a circular type of terminal is attached to the wire which allows the wires to be attached to the Dyna coils via bolt. I hope I'm making sense, I 've been painting all day.
"Don't tread on me"
NJWarrior is offline   Reply With Quote
Old 11-17-2012, 08:52 PM   #9 (permalink)
NJWarrior's Avatar
Holy crap did I breath to much paint, I'm over an hour late on my responce.
"Don't tread on me"
Old 11-17-2012, 09:04 PM   #10 (permalink)
kayak101's Avatar
I'm done for tonight but I'll reply tomorrow if I have any other questions. Thanks all!
03 Warrior
