Hard to starting agen - Page 9 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-21-2012, 07:10 AM   #81 (permalink)
Gilly's Avatar
Originally Posted by rquest View Post
A couple of us had this discussion a couple of weeks ago. I WANT YOU TO TRY THIS, once you get your bike started try squirting some spray brake cleaner or WD-40 around the intake manifolds or anyplace else you added or removed air cleaner stuff. If the idle jumps up you've got a leak.
I had an intake leak and when i sprayed WD-40 or starting fluid on where it leaked it would almost stall the motor instead of it raising the idle. I think if you have a leak and spray in what ever you use it floods the bike and lowers the idle. This is just my experience with doing this procedure with the leaks i had. Just adding this in there in case someone else's bike reacts the same way, you will know you still have a leak.
Old 11-22-2012, 03:52 AM   #82 (permalink)
Luv2LafMcc's Avatar
Originally Posted by joeysmith View Post
Sorry 2nd vid will be up soon my mouther in law got hit in her truck as I was doing the 2nd vid so I had to hall ass to her will het it up soon
its been almost 3 days...wheres the 2ed vid?
"Vegetarian" : Old Native American word for "bad hunter".
Old 11-22-2012, 04:24 AM   #83 (permalink)
heff's Avatar
I had this issue when the LCV was playing up before it failed completely. Try disconnecting the LCV and plug the two hoses going to the throttle bodies. Worth a try at least.
Heff
heff is offline   Reply With Quote
Old 11-24-2012, 10:08 PM   #84 (permalink)
joeysmith's Avatar
Sorry will get it up tomorrow I have been Workin on my car the last few days do to a bad motor .
joeysmith is offline   Reply With Quote
Old 11-29-2012, 11:37 PM   #85 (permalink)
Luv2LafMcc's Avatar
2 weeks Joey? Did you get er running? Did you find what the issue was?
Old 12-07-2012, 02:32 PM   #86 (permalink)
Luv2LafMcc's Avatar
JOOOOOOOOOOOOOOOOOOOOOOOEEYYYYY?!?!?
you left us hanging? Did you get your warrior working?
