#11 (permalink) | |
#12 (permalink) | |
Fuel Connections Should be on everyone's maintenance check list... . |
#13 (permalink) |
thanks man, i'll check mine. i've thought i smelled gas this summer a few times when i went into the shed but i too have other things in there and gas cans, so i put it off to that. but i keep thinking that i didn't smell gas before. i remember recently the other guy had the same problem.
#14 (permalink) |
I have seen this on bikes, cars, lawnmowers, etc. Not just gas but also coolant leaks.
With age and vibration the "press fit" will eventually back off or loosen. If the hose connection is old and tight, I will not twist, but try to pry the hose back a lil before applying much twisting torque. I have used the "rough up" method of repair mentioned above and also the "press" method for repair. . . |
#17 (permalink) |
I had the same issue with my '02 this past summer. I scuffed the brass piece and used a hard rubber mallet to pound it back in. To be safe I ordered a new one and replaced it before my TN trip, but the repaired one did not leak. The replacement part is fairly cheap and it gave me more ease of mind on my trip.
#19 (permalink) | |
anyone have an idea if it can be fixed - maybe JB weld? or welding using a gas welder and some brazing rod
