WARNING - Another Type of Fuel Leak, If you Own a Warrior Please Read - Page 3 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-21-2012, 08:55 PM   #21 (permalink)
Just checked mine, thanks.....mine is fine but I think some 'upgrade' is in order.
I think scuffing and JB Weld will do the trick.
VERY USEFUL THREAD, THANKS!
Old 11-21-2012, 09:28 PM   #22 (permalink)
Churchkey's Avatar
Originally Posted by christok View Post
+1
anyone have an idea if it can be fixed - maybe JB weld? or welding using a gas welder and some brazing rod
Braze will not work on the aluminum housing.
The boss od looks small = thin wall thickness. I doubt a pipe tap will work & if it did the boss would probably split when a taper pipe fitting is tightened.
IMHO the best fix would be to TIG weld an aluminum AN fitting on the housing outlet.
Forum member #113
Brother of the Wind
woody_church@comcast.net
Old 11-23-2012, 04:55 PM   #23 (permalink)
+1
akitadog said he used JB Weld on the first page of this thread:
"I had this happen on mine a few months ago and posted some photos on it. I had just washed the bike and was drying things off and hit the hose. It literally just fell out of the connector fuel flowing quick as I quickly fumbled to put it back in. Never leaked so I did not even know this was a problem. Roughed up both surfaces, cleaned them well and applied some JB Weld. Have not had any issues since!
Scary problem that most don't know about...."
e6bcal is offline   Reply With Quote
Old 11-24-2012, 08:25 AM   #24 (permalink)
BlackStar's Avatar
I'm guessing the casting may be pot metal (zinc) and not aluminum?
R.I.P. Justin Randol 1989-2008 Ride Like the Wind Son!
2011 WR450
2010 FJR1300
2007 FZ1
2005 Warrior
1978 Suzuki GS1000
BlackStar is offline   Reply With Quote
Old 01-23-2013, 05:04 PM   #25 (permalink)
Warrior50's Avatar
I think your right, I just checked mine and no leaks
Warrior50 is offline   Reply With Quote
Old 01-24-2013, 04:52 PM   #26 (permalink)
WallyGator's Avatar
Looks like another job for JB-Weld
WallyGator is offline   Reply With Quote
Old 01-30-2013, 10:28 AM   #27 (permalink)
cachenco's Avatar
Default WARNING - Another Type of Fuel Leak, If you Own a Warrior Please Read
Do I need to take the gas tank off to check this valve?
cachenco is offline   Reply With Quote
Old 01-30-2013, 11:17 AM   #28 (permalink)
No, it is right on the left side of the tank....follow the line (best to do this when your tank is low) to the tank and see if it is loose.
Old 01-30-2013, 11:29 AM   #29 (permalink)
cachenco's Avatar
Thanks
Old 04-10-2013, 10:15 PM   #30 (permalink)
I just had this happen today. I was riding home from work and felt my left pant leg near my knee getting wet. There hasn't been any rain so I figured it wasn't water. I looked down and saw something spraying on my leg. Pulled over and checked it and saw the fuel dripping. I made it home and checked it, and as soon as I touched the line the fuel just dumped out. I pushed the line back in and it slowed to a trickle. I incorrectly assumed that the leak was caused by the hose being loosely connected to that nipple, but when I attempted to fit a new hose clamp the nipple fell out like in the video. I'm gonna try the JB Weld. For those who have done this, how long have you been running it and how is it holding up?
FriggetyFrak is offline   Reply With Quote
