#21 (permalink) |
Looks like the mortons trees dont have holes under for the OEM style brake line mounts..
I might go for full length double race lines but Im not sure how to secure them around the trees to stop any rubbing? |
#22 (permalink) | |
There are more than a handful of members that have used a single hose to the RH caliper and a loop over the trailing edge of the frt fender to the LH caliper which will solve your problem and work just fine. |
#23 (permalink) |
hmm. The brake-line people recommended going for full length racing twin lines that have a double banjo connector at the master cyl.
I dont mind doing that either. As long as there are ways to isolate the cabled around any movement in the tree edges to avoid rubbing. |
#24 (permalink) | |
Here's an excellent link: http://www.brazeauracing.com/rswarrior/brakeline.html
#25 (permalink) |
The lower tree on mine has 4 allen head screws that i assume are for the steering stops. 2 of those allen head bolts, one on each side, has a hole all the way through them and are threaded on top for the bolt, but on the bottom of the tree the holes are a little less than 6mm, because i can just run a 6mm tap in there to thread it for my 3 way brake coupler. The holes are not threaded on the bottom. I wonder why the holes go all the way through the tree? If mine are different i will take a pic to show what mine look like.
#26 (permalink) | |
#28 (permalink) |
I got my big washer in today so i will be able to press my lower bearing on and maybe get the trees on. I am going to buy some fork oil and rubber washers tomorrow in hopes of getting the extensions on and maybe finishing these up. I am going to tap the right side hole under the lower tree to mount my brake coupler(3 way). I am hoping to get some thick rubber washers(1/4") to go on top under the risers and on bottom under the washer to sandwich the risers in rubber to maybe fix the problem. I wonder what others have done.
