Hello everyone - just signed up and I see this is a great place for advice and info otherwise.
So here it goes.... I live in Jersey shore and we got the worst of Sandy (that biatch). Managed to get the cars out but my 2003 buddy went scuba diving. The water covered the tank for at last overnight. I had the battery out and away on a tender so there were no shorts I suspect during the flood. I washed the bike 2 days after to get the salt off and let it dry well. There are no signs of corrosion anywhere other than what I can remember from before the storm. Connected the battery and the speedometer and all LEDs lit up fine and normal. All break lights, horn and so on seem to work ok. Went to start it and I got the funny buzz from the starter fuse box under the seat. When tried again, the (+) terminal in battery started heating up (smoked) so I stopped playing. Checked all fuses and they are good. ECU packet seems sealed and ok from outside - don't know if the water got in from the wire connectors but I guess the gauges wouldn't work if that was the case?!?! Next step was to try jump the start switch fuse box by shorting the (+) cables.... I heard the starter click but not turn. Every time I powered the jumper it would click but no turning, and if I maintained contact of power the jumper would get hot as if it's shorting (similar to battery terminal previously). Stopped that trial also before screwing anything up more than what it is. So this is where I am - You think the starter is gone? What do you guys suggest? I'm a good driveway mechanic, but never worked on the bike... nevertheless I want my good ol' friend back and rumbling. Help me out to get it fixed... Thank you and stay safe. Dante |
It is good news the bike would not start. I don't know if you remember tropical storm Agnes, but she submerged my Chevy Nova SS. I had it towed to a garage they dismantled the car, seats, dash, door panels, exhaust system, everything. Hosed it down with fresh water, drained, flushed and changed ALL fluids. Removed the carb, cleaned it. Put it back together, with new filters, plugs, points, distributor,etc. and it fired right up. I never had any flood related trouble out of it since then. A lot of other guys I know, their cars were never right after that flood. So be sure to change all of your fluids, drain your pipes, clean your fuel injectors, replace all your filters before starting it.
"Beer is proof God loves us and want us to be happy" Benjamin Franklin ![]() "Twas a woman who drove me to drink and I didn't even have the decency to thank her!" W.C. Fields
I would say your starter may be toast. Also i would find all of the wire connections, in the head light and under the seat, don't forget the rectifier, unplug them and spray some sort of corrosion spray on there because over time they will probably fail. You might be able to take your starter off and disassemble it and clean it up real good, spray it with the anti-corrosion spray and get it to work again. Probably the faster you do this the better.
i would say there is a good chance your motor is hydrolocked... meaning your cylinders are full of water. if it was submerged where the air filters were under water, it probably filled the airbox, and over time, through the throttle bodies and just packed the cylinders with water.
Pull the starter off, drain it, and get some wd40 going through it, and let it dry- it's probably full of water also. Once you can get the starter to function pull your spark plugs and crank the bike over- just in case there is water in the cylinders. While rebuilding/draining your starter, yank the drain plugs on the oil tank and bottom of motor and let that drain for a day its probably all milkshake brown and full of water also. just take your time, and yes, change every fluid in the bike, they're all compromised now.
"These bikes sound like pennies in a blender at idle" - Newwarorder PC III--Speed* --V-BAK--Coil Clean Up PC bars, Headlight ring, Custom world Backrest 06 Midnight Bike history: 1980 GS550, Yamaha Seca 2, Yamaha YZF600R, Honda VTX1300- |
Thanks capt and gilly. I am going to change all fluids and filters... as far as starter - maybe a dumb question - but once removed can I connect 12v wires somehow to see if it turns (or doesn't).... I guess I'm asking if there's a way to test starter off the bike?
Hey Steeda - salt water in the motor was my worst fear and was hoping not to hear that. I'll get on the starter this weekend and drain all I can. You guys think the motor is really compromised with water in it, even if I get it going at some point?
First thing I would do is pull the plugs and see if it will turn over, also change oil. Water probably filled at least one cylinder and there is now way it will crank. Then go from there. If it was under water over night crankcase is probably full of water also. ( ok I typed to slow but you can check starter off the bike, jumpers black ground to starter case red to starter terminal should turn if good.)
#8 (permalink) | |
time is of the essence.... i know, with everything else you have to clean up/rebuild this is bad news... Get it all drained asap...it will limit corrosion. WHEN you do get it running, plan on an oil change after the first ride... there may still be water in the crankcase. whatever you do don't let it sit like this too long... and as others said, yeah the starter to a 12v source will test out of the bike. Good Luck Sir!
#9 (permalink) | |
Outboard motors occasionally get dropped overboard, they get pulled up and cleaned up and are running again. Like the other guys said, time is of the essence. Salt water is the worst enemy steel has ever met, get all salt water out of everything, and flush with fresh water. When dry, spray everything with WD-40. It will run again, for how long depends on how well you get the salt out.
