Will this work? - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 12-08-2012, 11:49 AM   #1 (permalink)
Default Will this work?
I am making a new turn signal that has a white light in the center (LED, CREE).
I have drawn this circuit and am wondering if this will work. I know just enough to usually get myself in trouble, so I thought I would ask the gang.
1. R1 and R2 will be load so the riding lights have the same current as the incandescent bulb (act like the load eq's they sell)
2. Pulling 6.7vdc for the riding lights. I am okay with the riding lights being dimmer than stock.
3. When I turn on my blinkers, will I have ~18vdc going to the LED's?
4. Is R3 (1kohm) suitable for the LED's as a current limiting resistor
Here is the link to the LED's I am using
5mm Yellow High Flux LED | Component LEDs | Super Bright LEDs
5. The Zener Diodes are 9 amp capable with only a .42 forward voltage drop, I believe these are 'bigger' than I need but.......
I will probably use one of these for the CREE LED:
3A Adjustable step down switching voltage regulator
Being a fun project so far, any input from anyone would be appreciated.
Will it work?
What would be better?
Have I been drinking too much coffee?......lol
Thanks guys...............
Old 12-08-2012, 11:58 AM   #2 (permalink)
A comment:
There's no such thing as drinking too much coffee....
Carry on....
Old 12-08-2012, 12:43 PM   #3 (permalink)
I would tend to agree LD......lol
Old 12-08-2012, 07:31 PM   #4 (permalink)
MikeOlmt's Avatar
Looks good.... but I'm just beginning in circuit building so I could be off.
I'd give it a trial run and see how it works.
I don't think you'll be hitting the amber LEDs with 18v... I'm pretty sure you'll only get the current line voltage.. 13-14vdc.
Meh.. worth a trial run!?
Old 12-08-2012, 07:32 PM   #5 (permalink)
MikeOlmt's Avatar
btw, which program are you using to diagram the circuits? I'm interested!
Old 12-08-2012, 08:41 PM   #6 (permalink)
ExpressPCB - Free PCB layout software - Low cost circuit boards - Top quality PCB manufacturing
very simple program.....
I just tested with 12vdc and 24vdc. I was thinking of the 6/12v relationship to achieve a difference with the same LED's.
12/24 works wayyyyyy brighter than 6/12.....I have 5 on a breadboard with the lens sitting over it, looking pretty good. Once I get it blinking, I hope I see enough of a difference. If not, I will use a relay to turn off the riding lights while blinking.
At this point they don't look very different but I will play with the current limiting resistor.
12v
24v
Old 12-08-2012, 09:17 PM   #7 (permalink)
BTW.....I used to hang out at Dolphin Lanes between '72-'75....
Old 12-08-2012, 10:04 PM   #8 (permalink)
MikeOlmt's Avatar
Thanks man!!
I was using an app like this before.. gotta search for it again..
I think I still have saved schematics from it!! lol..
Old 12-09-2012, 02:42 AM   #9 (permalink)
Luv2LafMcc's Avatar
FYI :Radiantz LED Lighting
  • White outside ring with amber in the center. The light can be used as a running white light and the ambers come on in the center when the turn signal is activated.48 LEDs total. 24 white and 24 amber
  • $91 for a set
Old 12-09-2012, 03:30 PM   #10 (permalink)
Okay, I think I have this reduced the circuit to it's minimum. This circuit (thread) probably should have been listed with my turn signal thread (senior moment) Here is that thread:
Turn Signal Upgrade
I want to use ALL LED's for both turn signal and riding lights.
With this simple circuit, they will blink on/off when turn signals are used. The relay will simply turn them off. I can use the same riding light circuit to run my CREE LED. At 1.5amps, the CREE will act as my load equalizer.
Circuit (well actually just a picture of a relay and a couple of lines, elegance in simplicity.....lol)
Board for mounting in the turn signal bucket. (I love perf board)
