I have drag bars and the above mentioned risers, both from Yamaha's accesories site. I high side my bike and bent the bars. The current bars looked sweet, but I need bars that will come straight back just a few more inches. Looking to put the stock bars on with the current risers. Will this work? Thx!
I bought a stock bar a couple months ago and I have those same risers. I just havent taken the time to see if it would work. I figured it would require longer cables. If you try it, let us know.
I added the Barons 3.5" risers to my stock bars.
It put it back right where I want it and it works with the stock cables and brake lines.. BUUUUTTTT... The brake lines are stretched to the limit and the throttle cables will actually bind at full right turn (like maneuvering bike around parking lots). I'm not sure how tall the Yami risers are but if they add about 3" to the bar height.. you'll be in the same boat. Note... You can play with the rotation of the bars in the risers to slacken the lines and stuff a bit, but be careful you don't hit the tank with them too low!! Good luck! |
I have, Flat Bars STR-5PX75-14-00 and 6" Risers STR-5PX75-50-08 also added one Inch Riser Extensions for a little more pull back, cables are at there limit but work fine.
Just remembered I bought it this way but I'm almost sure these are stock cables Last edited by LASTCHANCE; 12-16-2012 at 08:29 PM. Reason: After thought |
#6 (permalink) | |
I believe Bruce aka Riverat has the Baron billet risers with stock bars which isn't quite as much set-back imo. You should be able to pick-up a Flanders drag bar, for little $'s, that will do the task and replace the damaged bar. In my gallery are several flavors using the Warrior bend bar, stock & medium Yami risers as well as the Flanders for an example and in my Flickr photos there is lots of stuff! |
The Yami medium risers and stock bars work well with the stock lines/cables...
I initially bought the tall ones and couldn't get it to fit with the stock lines/cables... God Bless, Doc S
![]() Psalm 27 1 The Lord is my light and my salvation— whom shall I fear? The Lord is the stronghold of my life— of whom shall I be afraid? 2 When the wicked advance against me to devour me, it is my enemies and my foes who will stumble and fall. 3 Though an army besiege me, my heart will not fear; though war break out against me, even then I will be confident. |
