Orient Express valve spring install question - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 01-03-2013, 07:43 PM   #1 (permalink)
Jbat's Avatar
Default Orient Express valve spring install question
So I am installing my set of Orient Express' valve springs and they come with 8 washers that I assumed were replacements for the lower spring seat. During install I noticed the Orient Express outer spring is shorter than the stocker, obviously its stiffer but still shorter, and the stock spring seat is shouldered, the Orient Express one is just a washer. So the question is...Is it to replace the stock spring seats like I thought or is it to go under the stock spring seat (which really doesn't make sense to me but OE is closed now so I thought I would ask you guys). Thanks!
Old 01-04-2013, 01:35 PM   #2 (permalink)
Jbat's Avatar
Alright so for anyone curious...I got an email from Orient Express Racing as well as talked with them on the phone and on the Warrior, the washers they supply with their valve springs go under the stock spring seat and act as a shim where on the standard Roadstar they replace the the stock spring seat. Who woulda thunk?!
Old 01-04-2013, 02:47 PM   #3 (permalink)
joshuaerdman's Avatar
Good to know, I have these springs sitting around that need to be installed some day.
Thanks for the info.
joshuaerdman is offline   Reply With Quote
Old 01-04-2013, 03:39 PM   #4 (permalink)
There's nothing about this in their Warrior instructions?
Old 01-04-2013, 06:12 PM   #5 (permalink)
Jbat's Avatar
The springs came with no instructions and I couldn't find anything about it on their website, do you know somewhere to look that I don't perhaps?
Old 01-04-2013, 07:15 PM   #6 (permalink)
Nope, I'm just astounded and amazed at the lack of instructions considering this isn't something that's an industry-norm by any means. It has to be communicated to be known. Or someone needs to measure standing-heights and somehow figure out the washer goes there (and not in another placement to make-up the missing spring height) so I'm glad you posted this! I mean, I realize the flat washer could not go on top of the stock shouldered seat and also couldn't fit correctly on top of the spring, but this needs to be communicated to have any level of confidence in the install.
Old 01-04-2013, 11:16 PM   #7 (permalink)
Jbat's Avatar
Exactly, I expected some sort of guidance because even though you need to know your way around a toolbox to put these in, like you said, there is no industry standard so who knows what setup your runnin
Old 01-05-2013, 12:50 AM   #8 (permalink)
I feel like I want to say good job for being alert and heads-up on this, many would have slapped it together and called it a day. But I won't mention that 'cause you'll get all big-headed hahaha! J/K good job on your part imo.
Old 01-05-2013, 01:35 AM   #9 (permalink)
Jbat's Avatar
Haha thanks, my wife says I'm not allowed to get any more big headed or I won't fit through the door
Old 01-05-2013, 01:44 AM   #10 (permalink)
Lmao!
