Throttle Body sync question---why, not how - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 06-06-2013, 05:20 PM   #1 (permalink)
sanny651's Avatar
Default Throttle Body sync question---why, not how
Today I sync'd my throttle bodies. Pretty easy to do really. I noticed since doing so that my bike starts a LOT quicker and easier than it did before. It's also noticeably smoother (less motor vibration). I can't really feel any difference in riding it (pull, torque, etc...), but that's not why I did it.
So as I was tooling away, I thought to myself "Self, why would these go out of sync?". So I'll pose the question to the forum here...what would cause something to go out of sync if it's left unmolested?
Do tell....
sanny651 is offline   Reply With Quote
Old 06-06-2013, 06:24 PM   #2 (permalink)
iowawarrior's Avatar
i just posted on the 3000 rpm vibe. i wonder if they sync-ed my TB's and that's why it's so much smoother. but yeah, how do they get out of sync in the 1st place.
Old 06-06-2013, 07:26 PM   #3 (permalink)
Mike7202's Avatar
how does anything get out of adjustment in the first place. to quote John Bender "Screws fall out all the time, the world is an imperfect place".
vibration, movement of the throttle linkage, heat cycles etc etc
“Life isn’t as serious as the mind makes it out to be.” ~Eckhart Tolle
Mike7202 is offline   Reply With Quote
Old 06-06-2013, 07:30 PM   #4 (permalink)
Mike7202's Avatar
Do tell....
not being a smartass but "unmolested" is a relative term. truly unmolested would indicate constants involving humidity, temp, light, motion, atmospheric pressure etc etc. I know that is an extreme example but I would say due to vibration alone nothing on our bikes remains unmolested once the engine fires
Old 06-06-2013, 07:55 PM   #5 (permalink)
cintron513's Avatar
Well said
"Folks that don't get it don't get that they don't get it...."
cintron513 is offline   Reply With Quote
Old 06-07-2013, 05:42 PM   #6 (permalink)
sanny651's Avatar
Perhaps to help me better understand this, let me ask another more technical question. What do the vacuum lines do... What service do they provide on these bikes? What governs and provides this vacuum (... And don't say the screw governs it. :-) The screw does something besides just threading into the TB).
I'd like to understand this more, if no other reason than to further fill the area of my brain that houses information I'll never use or truly understand.
Old 06-10-2013, 10:00 AM   #7 (permalink)
sanny651's Avatar
anyone?
Old 08-15-2013, 11:39 PM   #8 (permalink)
CJ.
CJ.'s Avatar
I realize this post is a few months old but is there a link to a throttle body syncing procedure someone could point out? The iPhone app search doesn't wanna find anything for me tonight.
2002 Red Warrior. Baron's stealth BAK, V&H big shots, PCIII USB.
CJ. is offline   Reply With Quote
Old 08-16-2013, 12:21 AM   #9 (permalink)
strud's Avatar
Mine now vibrates mode than it did. So can I do a synch in my garage or is if off to the stealership ?
The shortest distance between two points is for people that don't ride warriors
strud is offline   Reply With Quote
Old 08-16-2013, 12:27 AM   #10 (permalink)
If you make your own manometer or get a real kit for this,yes you can do it yourself. There is a thread here that shows how to.
Sent from Motorcycle.com App
