Bub exhaust or Vance and Hines Big Shots? - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 02-15-2017, 05:23 PM   #11 (permalink)
Originally Posted by rcoligan2 View Post
The big shots will be easier to find! The PCS pipe I think the coating will start to flake off.
From what i've read up on here, big shots seem to be the go to exhaust here
Shawking1985 is offline   Reply With Quote
Old 02-16-2017, 08:34 AM   #12 (permalink)
tapeworm's Avatar
I had the Big Shots and just picked up a set of Big Radius. Options are very limited. If noise is not an option, there are still a couple companies that make some pretty sweet set ups.
tapeworm is online now   Reply With Quote
Old 02-16-2017, 09:40 PM   #13 (permalink)
I love the look of that PCS pipe. Which baffle did you ahead put in it?
Sandytows is offline   Reply With Quote
Old 02-17-2017, 09:29 AM   #14 (permalink)
Here is my version of the V&H Big Shots, even just put a fresh coat of paint on the wrap.
Name:	VH Mod Exhaust.jpg
[FONT=Arial]
Compliments of ArizonaWarrior
Service Manual can be found here (thanks Robriquez)
Proper way to check oil level
Old 02-17-2017, 09:53 AM   #15 (permalink)
RobbSkllz's Avatar
Not to take away from the thread but what paint did you use?
RobbSkllz is online now   Reply With Quote
Old 02-17-2017, 11:33 AM   #16 (permalink)
useful info for someone else too i would assume.
VHT SP102, Flat Black
It will smoke for a bit when you first fire it up so be ready for that.
Name:	VHT SP102 Flat Black.jpg
[FONT=Arial]
Old 02-17-2017, 01:09 PM   #17 (permalink)
Default PCS pipe
Once I have it running and put some miles on the exhaust I'll post results. I did think about flaking and discoloration before purchase, if that happens, I'll wrap them. I think only the pipes coming form headers will go bad if anything after a while.
Gil-71 is offline   Reply With Quote
Old 02-17-2017, 02:26 PM   #18 (permalink)
I would just like to add that the quality of the V&H BS is second to NONE! I tried 5 or 6 pipes on my Warrior and in my own little shoot-out gave it the best score. Only problem is they are a little long for my taste.
Rick Quest
rquest is offline   Reply With Quote
Old Yesterday, 01:12 PM   #19 (permalink)
That's why I cut them to be short enough to remove the axle without removing the pipe. Was an easy mod.
[FONT=Arial]
