Size of 240 rear wheel - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 02-17-2017, 06:03 AM   #1 (permalink)
Default Size of 240 rear wheel
Hello from Russia. First sorry for my English. I need help or advice. Im going to install 240 size rear wheel for my warrior. But it diifficult to find in Rissia size 240/50/17. In shops 240/55/17 are very popular. Will i have some problems if i install 240/55 size? Never did it, thats why i need your help.
Thank you!
Sento is offline   Reply With Quote
Old 02-17-2017, 06:59 AM   #2 (permalink)
First welcome to the warrior family! Now about the tire, you should be able to use that tire size. If you have the correct wheel for that size and the swing arm has been modified to fit it. The only other issue would be if the tire will be too tall to fit under your rear fender.
Old 02-17-2017, 07:40 AM   #3 (permalink)
Shadow Warrior's Avatar
Welcome to the warrior family and the best warrior 4m.
agree with rcoglan2, you have a lot of mods to do before you can fit that tire on your bike. Good luck and be safe.
Old 02-17-2017, 08:38 AM   #4 (permalink)
Thanx!
Old 02-17-2017, 11:28 AM   #5 (permalink)
you can use a 225/45/17 or 235/45/17 car tire if you are going for the look
mkayx is offline   Reply With Quote
