Tune up - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 05-12-2017, 04:45 PM   #1 (permalink)
Default Tune up
My bike has 14k miles on it and I am looking to do a tune up on it. I have done a search and read as much as I can but I would just like a clean cut answer. What type of spark plugs should I use? What type of oil? What filter?
I bought the bike from a dealer in November with 12k on it but I don't know if a tune up was ever done. In about 3 weeks my father and I are going to ride about 450 miles and I just want to make sure everything is ok
Lokitruck is offline   Reply With Quote
Old 05-12-2017, 04:54 PM   #2 (permalink)
Good reads.....
Change Spark Plugs
Popular Mods and Repairs Knowledgebase
Also in the knowledge base (second link) you will have enough reading material on plugs, oil and filter for a few hours.
Old 05-12-2017, 05:47 PM   #3 (permalink)
Gilly's Avatar
You can ask all these questions in the search feature and get any answer you need. Plugs, oil, oil filter is a personal decision for you to decide on and there is plenty of info there that will help you decide. I run Amsoil oil, bosch oil filter, and iridium plugs.
Gilly is online now   Reply With Quote
Old 05-12-2017, 05:54 PM   #4 (permalink)
Desertboy13's Avatar
+1 Gilly... I run stock plugs Bosch filter and Mobil1 synthetic oil 20/50 cause it hot were I'm at.... One thing is since I switched to full synthetic oil my engine sound's quiter n smoother .....
Sent from my Z831 using Tapatalk
Desertboy13 is online now   Reply With Quote
Old 05-13-2017, 09:52 AM   #5 (permalink)
mkayx's Avatar
at 14k your plugs should not be worn i run ngk plugs (stock) shell t6 oil and k&n 303c oil filter same as the 303 filter BUT it is chrome not black
mkayx is online now   Reply With Quote
Old 05-13-2017, 01:38 PM   #6 (permalink)
rumblemonkey's Avatar
Consider a fork oil change at 14,000, I believe this is what the maintainence manuel calls for also-Of course, the other items too-
rumblemonkey is offline   Reply With Quote
Old 05-13-2017, 08:42 PM   #7 (permalink)
The only reason i want to change the plugs is the bike had 12k when i bought it and im not sure if they have ever been done.
Old 05-13-2017, 09:33 PM   #8 (permalink)
mkayx's Avatar
resistor plug are good for 30k
platinum 60k
double plat. 80k
iridium plugs 100-120k
Old 05-13-2017, 11:48 PM   #9 (permalink)
The bike runs great so ill probably just stick to the oil change and ill try to change the fork oil. The only reason i was going to change the plugs was the service manual said every 8k miles
Old 05-15-2017, 10:56 PM   #10 (permalink)
joeyalessi's Avatar
I run Pulstar plasma plugs, Either Mobile 1 full synth or Amsoil, and a K&N filter
God gave rock-n-roll to you
joeyalessi is offline   Reply With Quote
