My version of SeifertR's front horn relocate... - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 05-10-2009, 03:05 PM   #1 (permalink)
yamaweezle's Avatar
Default My version of SeifertR's front horn relocate...
I really liked this horn relocate mod, & I thought I'd contribute with a step by step of how I did it...
Step #1, unplug the front horn & remove the two 8mm head retaining bolts.
Step #2, locate the two 5mm allen head bolts at the back of the starter bracket, & remove them.
The hardware I used, was bought at my local Ace Hardware & was roughly $10.
2 - 6mm x 1.0 chrome allen bolts approximately 2" long.
2 - 1/4" ID x 3/4" long chrome spacers
2 - 1/4" chrome flat washers (omit the 6mm flat washers, they were too small to use)
Step #3, I reindexed the horn's mounting bracket so the horn would point down when installed...I removed one of the horn's assembly screws & moved the bracket one space back - counterclockwise...Reinstall the assembly screw ahead of the bracket...
...like so.
Step #4, install the bolts, washers & spacers through the mounting holes of the horn bracket.
Step #5, install horn assembly into starter bracket bolt holes. Tighten to spec, & reroute the horn harness over to the left side of the engine. I simply ran it under the voltage regulator, securing it into the one ratcheting clamp directly below it. I then secured any loose harnesses with zip ties.
The end result is very clean & looks as if it belongs that way...Thank-you SeifertR for a great mod!!!
Old 05-10-2009, 03:12 PM   #2 (permalink)
wyomingwarrior's Avatar
Default Re: My version of SeifertR's front horn relocate...
GREAT how to !!!! Will definitely add this to the DIY Mod List.
Thanks!!!!
My Pics ..... DIY Mods List ..... Popular Mods ..... KyleNV wide tire kits and more
wyomingwarrior is online now   Reply With Quote
Old 05-10-2009, 03:51 PM   #3 (permalink)
Thanks!!!!
+1 !!!
Truethinker is offline   Reply With Quote
Old 05-10-2009, 06:08 PM   #4 (permalink)
yamaweezle's Avatar
Thanks guys...Now onto cleaning up the brake switch area.
Old 05-11-2009, 12:21 AM   #5 (permalink)
Pep
Pep's Avatar
You may want to contact Chuck Brazeau (aka BrazeauRacing). He did a nice relocation of the brake switch and the horn.
Pep is offline   Reply With Quote
Old 05-11-2009, 01:26 AM   #6 (permalink)
SiRaDuDe's Avatar
Nice...
Remember, if you take the horn apart you can swing the connectors towards the bottom if it would look any beter...
All you have to do is remove the outside cirlce of bolts and spin the base to desired direction and put bolts back on again.
<a href=http://www.softwaredesignspr.com/warrior/siradude_2.jpg target=_blank>http://www.softwaredesignspr.com/warrior/siradude_2.jpg</a>
SiRaDuDe is offline   Reply With Quote
Old 05-11-2009, 01:58 AM   #7 (permalink)
I think there was a recent post about using hydraulic switch to replace the OEM one. I think that's the route I'm going to go along with doing the horn as it was done here. Nice write-up.
Old 05-11-2009, 04:45 AM   #8 (permalink)
jarv's Avatar
Here's my version inc the hydraulic brake switch.
Old 05-11-2009, 05:57 AM   #9 (permalink)
2warriors9802's Avatar
Great job looks neat and like it should be there. I wish the ACE near me had chrome hardware they are very limited in choice.
2warriors9802 is offline   Reply With Quote
Old 05-11-2009, 07:10 AM   #10 (permalink)
Don't think your links working Jarv.
Jarv's version of relocating brake switch: http://rswarrior.com/forums/p/28629/391716.aspx#391716
