Turn Signal Upgrade - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 12-07-2012, 11:42 AM   #11 (permalink)
Originally Posted by Luv2LafMcc View Post
Hey Scawein,
That's a $50 - $100 flashlight your cannibalizing...
could you make this mod work with these components? They have them board mounted already. I used this site to replace (upgrade) the LED's in my kitchen stove Hood.
$14 per light (CREE and Lens)??
You rock.......can this forum get any better.......lmao......
I will look towards those and I just might get to put my flashlight back together......L2L.....that there is some great info....thanks....
I will post up the result.......
Old 12-07-2012, 12:30 PM   #12 (permalink)
Luv2LafMcc's Avatar
Originally Posted by scawein View Post
You rock.......
Cool... I hope this works... I see this a being a VERY popular mod: Increase your conspicuity (being seen) while not adding a lot of extra outriggers.
keep us posted...
Old 12-07-2012, 02:23 PM   #13 (permalink)
Luv2LafMcc's Avatar
YUP!!
check to see if any of these can be used: Custom LED Universal Round LED Clusters
Old 12-07-2012, 06:48 PM   #14 (permalink)
YUP!!
You go L2L....The other LED's you sent over have a max of 280 lumens compared to 600 lumens from the one I am using. I also like the metal shroud on the flashlight one since it will act as a heat sink for the 9 watts (6v/1.5amps).
The clusters look like a good swap for the tailights on my FJR.....thanks!!!!
Old 12-07-2012, 07:32 PM   #15 (permalink)
Luv2LafMcc's Avatar
The Glenda lights on my bike are 12 watts per light unit (1 unit = 3 LED's) with 900 lumens .
so on full power (there dimmable), my glenda fork lights have 1800 lumens??? can you just add them together like that?
Old 12-08-2012, 07:45 PM   #16 (permalink)
Yes they can be added together. I am learning more as I am playing with the circuit for the turn signals. My high flux LED's came in (Yellow).
I like the single CREE LED from the flashlight. I even like the metal housing, think it looks kewler than the single lenses...and gives me a little more room for angling it down a bit.
I will post more as it comes together....
Once I finish the turn signal circuit, I will get the CREE running. I would almost like to try a higher voltage on the CREE but am worried about blowing it.
BTW...L2L, your headlight looks kewl, have liked it since I saw it
Old 12-09-2012, 02:41 AM   #17 (permalink)
Luv2LafMcc's Avatar
new option:Radiantz LED Lighting
  • White outside ring with amber in the center. The light can be used as a running white light and the ambers come on in the center when the turn signal is activated.48 LEDs total. 24 white and 24 amber
  • $91 for a set
Old 12-09-2012, 03:20 AM   #18 (permalink)
yellowbee's Avatar
Those look kinda cool but I don't think you would gain much projected light.
yellowbee is offline   Reply With Quote
Old 12-09-2012, 04:10 AM   #19 (permalink)
Luv2LafMcc's Avatar
nope...your right YB, no projected light, especially when compared to a 600+ lumen lights. These would be an easy swap out, inexpensive alternative for some that want to add the benefit of "being seen". Meaning quick easy DRL/ conspicuity lights.
Scawein's projected light will come from 2 $100 flashlights, and mine are in the $400 rent district.
Old 12-09-2012, 04:14 AM   #20 (permalink)
Luv2LafMcc's Avatar
Thank you sir!
Admittedly, Im way more impressed that your designing and making your own...I just clicked a button online...
