Official VMAX Horsepower, Torque - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 06-14-2008, 07:07 AM   #1 (permalink)
Default Official VMAX Horsepower, Torque
Not sure if this has been posted here yet but a link from yamaha.com.au takes you to a mini site that states official HP and Torque for the VMAX. I know the Starmotorcycles.com site doesn't.
Engine type - 4-stroke, DOHC, 4-valve, V-type 4-cylinder
Engine cooling - Liquid cooled
Displacement - 1,679cc
Bore x stroke- 90.0 x 66.0 mm
Compression ratio - 11.3:1
Maximum power - 147.2 kW (197.4 HP) (200 PS) @ 9,000 rpm
Maximum torque - 166.8 Nm (123.01 lb/ft) (17.0 kg-m) @ 6,500 rpm
Lubrication system- Wet sump
Fuel System - Fuel injection
Clutch type - Wet, multiple-disc diaphragm spring
Ignition system - TCI
Starter system - Electric
Transmission system - Constant mesh, 5-speed
Final transmission - Shaft drive
Primary ratio - 1.509
Secundary ratio - 3.082
Gear ratio-1st gear - 2.375
Gear ratio-2nd gear - 1.810
Gear ratio-3rd gear - 1.400
Gear ratio-4th gear - 1.115
Gear ratio-5th gear - 0.935
Fuel tank capacity - 15 litres
Oil tank capacity - 5.9 litres
Chassis
Chassis: - Aluminium, Diamond-shaped
Front suspension system - Telescopic forks, 52 mm
Front travel - 120 mm
Rear suspension system - Swingarm (Link-type suspension)
Rear travel - 110 mm
Caster angle - 31
Trail - 148 mm
Front brake - Dual discs, 320 mm
Rear brake -Single disc, 298 mm
Front tyre - 120/70 R18M/C (59V)
Rear tyre - 200/50 R18M/C (76V)
Dimensions
Length - 2,395 mm
Width - 820 mm
Height - 1,190 mm
Seat height - 775 mm
Wheel base - 1,700 mm
Minimum ground clearance - 140 mm
Service weight - 310 kg
ozwarrior is offline   Reply With Quote
Old 06-14-2008, 12:54 PM   #2 (permalink)
Frankenstein's Avatar
Default Re: Official VMAX Horsepower, Torque
Yep - those are the specs.
So who is going to order one? :-)
Frankenstein is offline   Reply With Quote
Old 06-14-2008, 01:50 PM   #3 (permalink)
Eric357's Avatar
WOW 197hp?? Thats unbelievable. Awesome numbers. That bike is going to suprise a lot of people.
Eric357 is offline   Reply With Quote
Old 06-14-2008, 01:55 PM   #4 (permalink)
kja
WARNING!!! THIS MACHINE MAY NOT BE FOR EVERYONE. That is some serious power!
kja is offline   Reply With Quote
Old 06-22-2008, 03:50 PM   #5 (permalink)
WannaB's Avatar
Yup, zero to DEAD in 2.1 seconds. still a bad bike though. I wonder how manysquids will die on it. Im sure mikey (exharleyrdr) cant wait to high side it off the show room floor. hehe. Heck, I would probably high side it too, and I ride slow. almost 200HP, from a factory bike??? times are getting crazy. I remember when 750cc was a BIG BIKE. the quest for TOO MUCH power.
WannaB is offline   Reply With Quote
Old 06-22-2008, 04:14 PM   #6 (permalink)
So far about 900-1000 have been order - and there are 54+ members on www.starVmax.com that have shared their pre-order claim number.
Needless to say my order is in since 6-4-08. :-)
Old 06-22-2008, 09:22 PM   #7 (permalink)
WannaB's Avatar
congrats Ollie. I know you will not ride over your head. and have a better chance to handle it. but what about these idiots that have to have it, because it is the most powerful bike. LOL I saw a guy buying a ZX-14 for his first bike. salesman was trying to talk him out of it even. Darwin award winner waiting to happen. Im sure this bike will draw them like flies also. I just hope yamaha fixed the head shake problem they had with the old one.
Old 06-22-2008, 09:56 PM   #8 (permalink)
warrior480's Avatar
When my Warrior was delivered it had a VMAX in the trailer with it. The guy told me for every 10 they sell, after a year only 3 were still on the road. That was the previous vmax, I bet that number will be even worse for the new one!
warrior480 is offline   Reply With Quote
Old 06-22-2008, 10:01 PM   #9 (permalink)
heavyhitter's Avatar
Numbers from manufactures are always inflated and taken at the crank. I would be surprised if it hits 150-160 on a dyno in the real world, however that is still alot of engine!
heavyhitter is offline   Reply With Quote
Old 06-22-2008, 10:48 PM   #10 (permalink)
Originally Posted by WannaB
... I just hope yamaha fixed the head shake problem they had with the old one.*
This is a brand new bike - the only thing in common with the old VMax is the name and a bit of styling.. No Yamaha in the past 10 years had this problem. Nothing to fix here for me. Its new and for sure wont have that problem. This is not 25 year old technology - it's the latest in what Yamaha can build.
According to a test riders I spoke to, it will out-handle the Warrior - he even said he liked the ride a lot more than on the burger king. If that's only close to be true, it will be a great handling bike.
