Just arrived. I got the 1.5 inch diameter 9 inch rise. Amazing looking chrome, Amazing quality, flawless joints where the risers meet the cross bar.
Pics later. Will be installed over the dark depression season (winter). I'll be taking a lot of step by step pictures and notes along the way, riser bolt size, electrical wire extension lengths, soldered/mecahanical splices, etc, etc,. Wires will be routed internally.
Funny, I actually find myself "hoping" that when I dissassemble my front end this winter to check for something bent, that I actually find something....safety first right!!!! santa can't refuse safety!!!!! will be watching for the pics jeff!
I think you should start now!
Warrior Brothers World Wide Map Cleverly disguised as a responsible adult. Everything looks a bit better and your problems don't seem quite so bad from the saddle of a bike! - Jack Conrad
#7 (permalink) | ||
#8 (permalink) | |
Then please check your riser spacing, You need 3-1/2" riser spacing for these to be a direct bolt-on. I'm planning to do a little bit of machining to the top clamp of the triple-tree if need be.
#9 (permalink) | ||
#10 (permalink) | |
100mm riser centers to be exacton the Warrior (Approx 4") ... 3-1/2" spacing is std HD As Darkstar stated, it's a bolt-on |
