What Should I Add when getting recall done? - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 02-28-2007, 10:41 PM   #1 (permalink)
Default What Should I Add when getting recall done?
I have an 02 warrior that has not had any recall work done. I am looking into HC Pistons and new 5th gear. I have serched and read hundreds of post but am still unsure. My dealer only wants to install parts that they can get. So, are the speedstar HC pistons worth the money and will it be a simple swap out or will I need additional parts also. Any information and suggestions would be great.
2002badassrsw is offline   Reply With Quote
Old 02-28-2007, 10:46 PM   #2 (permalink)
DFW_Warrior's Avatar
Default Re: What Should I Add when getting recall done?
HC pistons, cams, springs, pushrods, lifters, 5th gear, and ummmmm....... yeah, that should just about do it. That's what I would've done to mine if I had a recall on it.
Bill ('04 DL1000) ('00 KLR650) ('05 YZ250)
A good ride is one from which you can walk away. A great ride is one after which you can use the bike again.
DFW_Warrior is offline   Reply With Quote
Old 02-28-2007, 11:16 PM   #3 (permalink)
RaySDF250's Avatar
What DFW said.
RaySDF250 is offline   Reply With Quote
Old 02-28-2007, 11:50 PM   #4 (permalink)
the_editor's Avatar
If they refuse, go elsewhere... surely someone on here will be able to tell you who will accomodate you!
the_editor is offline   Reply With Quote
Old 02-28-2007, 11:56 PM   #5 (permalink)
vector18's Avatar
How about some pics of your bad ass rsw??????
vector18 is offline   Reply With Quote
Old 03-01-2007, 12:59 AM   #6 (permalink)
fcwarrior's Avatar
Check with Patrick Racing or Orient Express for their big bore kits. Whatever you do, I'd say the 5th gear swap is a must. Have fun!!
fcwarrior is offline   Reply With Quote
Old 03-01-2007, 04:46 AM   #7 (permalink)
timoken's Avatar
ah yeah and a new pickup-sensor [img]/emoticons/emotion-5.gif[/img]
timoken is offline   Reply With Quote
Old 03-01-2007, 06:47 AM   #8 (permalink)
iowawarrior's Avatar
you're lucky. free upgrades. when i bought mine, used, i didn't know about the recall till i read about it here. i went out and looked for the "stamp" and it wasn't there and i thought "EXCELLENT" but when i called about it, they said it had been done. i even called yamaha corp. what a letdown. now i have to do it the old fashion way. actually pay for the whole thing.
iowawarrior is online now   Reply With Quote
Old 03-01-2007, 08:08 AM   #9 (permalink)
JREMACLE1's Avatar
My dealer wanted $1200 just to open it up and put it back together.
JREMACLE1 is offline   Reply With Quote
Old 03-01-2007, 10:44 AM   #10 (permalink)
The_Bear's Avatar
1) RoadStar 5th Gear
2) High Compression Pistons
3) HD Valve Springs
3) HP Camshaft.
4) Ported rear exhaust manifold
5) Ported Heads
This is w/o going big bore.
The 5th gear swap is listed first as this the ONLY oppurtunity to get it done for free labor. (I didn't do it on mine and everytime I get on the highway, regret it).[[img]/emoticons/emotion-6.gif[/img]]
Good Luck!
The_Bear is offline   Reply With Quote
  Road Star Warrior Forum : Yamaha Star Warrior Forums > Warrior Forums > Total Recall
