Midnight 240 wide tire - Page 2 - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 03-19-2010, 09:12 AM   #11 (permalink)
bja72774's Avatar
Default Re: Midnight 240 wide tire
I have the 260 kit by Eric (G&S Cycles)...if you are going for a kit I would suggest spending a little more and getting the 260 kit...( I actually now wish I went with a 280..but then there are more pieces that need to be modified) If you would like to stay with a 240...I would suggest you send the wheel to Kosman to get modified and look up DIY 240, Just dremel out some of the areas for clearance and your good to go...
Just my opinion though...
bja72774 is offline   Reply With Quote
Old 01-09-2019, 06:29 PM   #12 (permalink)
Who as the contact info the various shops that do the wide tire kits
Hogrider is offline   Reply With Quote
Old 01-09-2019, 06:47 PM   #13 (permalink)
Shadow Warrior's Avatar
Make sure and check out kylenv.com or Kyle @ 775.351.8221
Old 05-05-2019, 11:40 AM   #14 (permalink)
Originally Posted by warrior_pr View Post
Hello everyone,I love the 210 look but I can't wastemoney no more.I just want to see some pictures of the midnights with the 240 kit installed before ordering. Who is the best doing these upgrades? Kosman, Performance..another shop?? Do they make the red line on the wheel same as stock? Can the wheel broke if I take a big bump/hole?Any input is very appreciated or just point me to users that has a midnight and the upgrade done. Thanks!!!!!
Edgar Rodriguez, EXTREME Choppers, Camuy, Puerto Rico
787-585-9577 Tell him Henry from PPG gave you his mobile number.
canelo61 is offline   Reply With Quote
Old 05-05-2019, 11:42 AM   #15 (permalink)
This is my Warrior...
Old 05-09-2019, 10:28 AM   #16 (permalink)
Kylenv is the man to contact
Old 05-09-2019, 10:40 AM   #17 (permalink)
So Canelo does your guy make a kit for the wide tires?
Does he modify the swingarms?
Does he modify the rims to accept the wide tire?
Old 05-15-2019, 09:28 AM   #18 (permalink)
battleborn's Avatar
how do you not rub? I have a 260 and rub a little. you running a air shock
battleborn is offline   Reply With Quote
Old 05-15-2019, 09:34 AM   #19 (permalink)
i-man's Avatar
Exactly. I have been looking at his work and when I am ready (read, when I have the money), he will be the man that does the work for me. His attitude and pictures of his work speak volumes.
https://www.kylenv.com/
If it's small enough to eat in one sitting, go ahead and hit it. If larger than that, you might want to try and miss it.
i-man is offline   Reply With Quote
Old 05-15-2019, 09:35 AM   #20 (permalink)
madtom421's Avatar
Where are you rubbing? When I installed my 260 kit I was rubbing on the inside of the fender, I had to make a custom shim to move the tire over and had to space out one of my fender stays and stretch the rear fender slightly. It's a common issue for the rear tire to not fit perfectly centered in the fender. They're used to be a member that sold custom fender stay spacers and offered a service to widen the stock fender but he was banned due to some unfortunate circumstances.
You can be anything you want on the internet, Strange so many people choose to be stupid. -Mark Twain-
