Dry Break O-ring replacement? - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 08-20-2016, 03:39 PM   #1 (permalink)
Brizzman's Avatar
Default Dry Break O-ring replacement?
Where is the quickest and easiest place to get an O-ring for the tank side under seat dry break? I need one like right now!
I'm at the DMV registering the Warrior i just got delivered today. It was shipped with the main tank empty. I filled it up and headed down to the DMV. When I got here i saw that a steady stream of gas was running down the side. I unclipped the under seat drybreak and can see the broken spot in the tank side O-ring.
I have the drybreak unplugged right now, so it doesn't dump the whole 3 gallons out while I'm waiting at the DMV.
I need to get a new O-ring ASAP.
Brizz
05 Speedstar Stage IV
Brizzman is offline   Reply With Quote
Old 08-20-2016, 03:50 PM   #2 (permalink)
If you know the size, any auto parts store. I bought a awesome kit of many sizes, many in each size, at Harbor Freight for something like 20 bucks.
Old 08-20-2016, 03:56 PM   #3 (permalink)
Brizzman's Avatar
I'm hoping I can find something like that. I just got off the phone with the Yamaha dealership parts department. They can order one, but it will take like a week. I'd really like it fixed before I have to ride it home, about 20 miles away.
Brizz
Old 08-20-2016, 04:06 PM   #4 (permalink)
rij1's Avatar
Remove the one you have and match it at Napa auto.
2002 XV1700 Roadstar Warrior
My Mods
Cobra Fi2000 PowrPro with CVT(Non-Black)
Speedstar Gen2 Exhaust
Rudy Jeremias
(562)303-6036
rij1 is online now   Reply With Quote
Old 08-20-2016, 08:10 PM   #5 (permalink)
Some years ago in a thread here I read a documented repair was successful using Viton 3/4 x 9/16 x 3/32 o-rings for stock dry breaks (Size #113) so I bought a few to have on-hand just in case. Most auto part stores have them in Viton. Turns out Buna-N and Nitrile seem to work just as well (and are in the same family of materials its just that Viton is a patented name). Home Depot for Buna-N or Nitrile. If they are nicked during install they will tear in a short while. Some use WD40 brand as lube to set the o-ring then squirt an extra dab of WD40 into the female end and gently click the dry break halves back together until there's an audible click.
arizonawarrior is online now   Reply With Quote
Old 08-20-2016, 08:56 PM   #6 (permalink)
Brizzman's Avatar
Thanks everyone. I went to an O'reilly auto, 'cause it was closest. They had one of the kits behind the counter and got me one O-ring from it that worked for $1.66. The problem is solved.
Unfortunately, on the way home it had a MAJOR leak from the gas tank. Like in this thread:
https://www.rswarrior.com/forums/13-t...ease-read.html
The hose fell completely out and drenched my left leg and the left side of the bike in gas. I pulled over and got the nipple stuffed back in. It only leaks a little bit now. Gotta fix that.
Brizz
Old 08-20-2016, 11:40 PM   #7 (permalink)
rij1's Avatar
D a m n, it just wasn't your day.
My Mods
Rudy Jeremias
(562)303-6036
Old 08-21-2016, 10:04 AM   #8 (permalink)
Usually when we notice a fuel leak thread and its creator has not already included the events in our record thread, we ask 'em to add their story too. If you would, you can add your leaks into the thread. It houses these in one place so if an opportunity arises we can go to back to Yamaha again: https://www.rswarrior.com/forums/12-g...fuel-leak.html
That thread is intended to also house uploaded files (jpg's, pdf's) so even if a Forum software change occurs the images will remain part of the record. The the Go Advanced button and then Manage Attachments.
Old 08-21-2016, 10:04 AM   #9 (permalink)
Bump.
Old 08-21-2016, 02:17 PM   #10 (permalink)
Brizzman's Avatar
Done.
Brizz
