STAGE IV HELP - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 11-13-2010, 09:08 PM   #1 (permalink)
marine warrior's Avatar
Location: Garner NC yes the same place as Garner Warrior
Send a message via AIM to marine warrior
Default STAGE IV HELP
I have reciently procured a 2002 Stage 4 bike with all the proper documentation.
I can verify the ECU Injector's pistons, speed star pipe, velocity stacks every thing that is visably related to the kits short of the internals. I took it to a dyno shoot out to day to be embarrassed by a group of HARDLEYS.
Again a full speed star stage 4 kit with a 31 tooth pully. I posted 80 hp and 105 torque The Bike dose not have a PC111 but and theECU is set to CO O1 =+14 and CO 02 =+14 The Dyno looked very smooth with the power curve peaking at about 4500 rpms before falling off.
I knowI need to put in a pc 3 and have a custom map butI really dont believe that it will give me the numbers I am looking for of about 95+ and 110+ which is a reasonable expectation out the factory kit. I did do a compression test on the rear cylinder in my exploration of the elusive HC pistion I did confirm based on a set of pictures of the brass colored dome that I do indeed have SS HC Pistons. It posted 170 psi vs my Wifes bike with a 160 psi this was done knowing that hers is completely stock.
Thanks in advance
Private Pyle I'm gonna give you three seconds; exactly three-fucking-seconds to wipe that stupid looking grin off your face or I will gouge out your eyeballs and skull-PHUCK you! ONE! TWO! THREE!
marine warrior is offline   Reply With Quote
Old 11-13-2010, 09:26 PM   #2 (permalink)
Banned
btk572's Avatar
Default Re: STAGE IV HELP
sounds like you need to look deeper in the motor, we have a stock 102 no hc pistons doing 88 hp and 118 torque and no pc or anything right now, just pipes . the thing just runs real good, btk572
Old 11-13-2010, 11:38 PM   #3 (permalink)
oldman's Avatar
It does more that just run real good. It has to be the one in a million cuz it is making much more HP and torque than any other stock bike on the planet. ****, it's making more than many modded bikes, particularly the torque. What set of pipes is raising the torque by so much?
My life is based on a true story.
#584
Old 11-14-2010, 05:00 AM   #4 (permalink)
bruce59's Avatar
You can do a lot with a PC and Dyno tune. Mine's giving about the better #s that you mentioned above after the initial tune ... we did not have time tofine tune the map for max power. A proper tune with those components can find you 10 hp though...
bruce59 is offline   Reply With Quote
Old 11-14-2010, 08:08 AM   #5 (permalink)
Churchkey's Avatar
Your #'s = those ofa low compression bike.
Did you pull the plugs & look at the top of the pistons to verify they are domed instead of dished as we discussed via cell?
BTW: +14 on the CO with a SS ECU & SSinjectors??
IMHO the bike would flood the engine with fuel @ anything other than full throttle.
What color are the injectors?
Forum member #113
Brother of the Wind
Old 11-14-2010, 08:35 AM   #6 (permalink)
Shag's Avatar
Centerline/Steve would be another good person to talk to about this since he had two Stage IV Warriors. Better get that thing runnin' right before you get embarrassed by ANOTHER Harley.
"Scar tissue is stronger than regular tissue. Realize the strength - move on." -Henry Rollins
Life is uncertain. DON'T SIP.
"I haven't taken my pants off. Yet."
Shag is offline   Reply With Quote
Old 11-14-2010, 08:49 AM   #7 (permalink)
MarineWarrior, I agree with Woody your Stage4 numbers should be better: https://rswarrior.com/forums/t/120968.aspx Also, its possible but expensive to build a Stage4 HD which can be a wicked machine too, on a dyno, but who knows possibly won't perform as well on the road.
Billy, I agree with Oldman. But you still haven't posted pics and info on your bike in your galleryso its hard to help you see if maybe there's more to your bike than you realize. Post those pics okay!
Changing gears, I wonder if there's some HP and TQ numbers being posted that were "at-the-crank" numbers, and others that were "rear-wheel" dyno numbers, possiblyexplaining why that water is getting muddyhere? I dunno, just wondering.
Old 11-14-2010, 09:21 AM   #8 (permalink)
Woody,
Here is what I have done to check the pistions' I did a completed compression test on the back cylinder unhooking the decomppression solenoid and acheived 170 psi. I did the same on Anna's Bike and achevived 160 psi. I found this link below with these pictures
https://rswarrior.com/forums/t/24542.aspx?PageIndex=1with this picture below
The color of the piston in the cylinder seems to match the picure of the piston. Looks kinda Likebrass'ie The Injectors are Grayand again the it apears to have all the other componets thatare on the outside of the bikeI have been able to check every thing by eye except the internals.
I am reall at a loss on this one. Here is a link where others have seemed to have the same problem. look below Fyi I had the fuel on the ecu marked up to 50 on both pistons and it never acted funny. Call me if you have a chance. thanks Jim
https://rswarrior.com/forums/p/21121/327008.aspx#327008
Old 11-14-2010, 09:28 AM   #9 (permalink)
bruce59's Avatar
It is the shape of the piston you need to check ... not color . you need to feel the 'step' on each side . the stock piston is flat across this surface.
Old 11-14-2010, 09:46 AM   #10 (permalink)
what type of tool do you recomend?
