how much oil - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 10-21-2011, 03:26 PM   #1 (permalink)
Midnight Ray's Avatar
Default how much oil
oil level just checking the manual calls for 4.2 L with filter change but i just did a fall oil change and had to put in 4.9 L to show at full on dipstick without screwing in the dipstick i have seen this some where here before but cant find it now has any one else noticed this..thanks Ray...........
Midnight Ray is offline   Reply With Quote
Old 10-21-2011, 03:42 PM   #2 (permalink)
markdorland's Avatar
4.3 US Quarts with filter change. Run the motor for 10-15 minutes with a ride or not and then remember to pull BOTH plugs.
markdorland is offline   Reply With Quote
Old 10-21-2011, 04:11 PM   #3 (permalink)
thanks did the two drain plugs and filter and followed warm up and idle procedures but it still toke just under 5 L to get to full mark ,,,,,,,,,,,,,,
Old 10-21-2011, 04:28 PM   #4 (permalink)
With the filter I put on (probably a little larger than stock) I added 5 qts on the button, and when the oil is checked according to the Star motorcycle procedure, level is right on the upper mark on the dip stick.
scubabrew is offline   Reply With Quote
Old 10-21-2011, 04:40 PM   #5 (permalink)
me to followed yamaha star video right on full mark just under 5L this might sound like a dummy but how close is a litre metric to a us Quart,,
Old 10-21-2011, 05:57 PM   #6 (permalink)
danigar's Avatar
12 fl. oz = 355 ML according to my bottle of beer
i always change my oil and filter using 5 quarts total
refill with 4 quarts, ride it around the block 1 time and top it off with the last quart
have never had a single issue with oil leaks
according to google,
1 US quart = 0.946352946 liters
danigar is offline   Reply With Quote
Old 10-22-2011, 11:03 AM   #7 (permalink)
thanks for the info guys .....looked up records from my last change and it was the same.. ya i keep records of mileage and oil changes from year to year just had find them..
Old 10-22-2011, 02:04 PM   #8 (permalink)
06_warrior's Avatar
+1 I do the same. I always record the date and milage when i change the oil + filter/tires/transfer case oil etc. and i save the receipts.
06_warrior is offline   Reply With Quote
