elite forward controls install? - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 07-01-2013, 06:34 PM   #1 (permalink)
Ama
Ama's Avatar
Default elite forward controls install?
I bought some used forwards the other day and I take it they won't be coming with instructions. . Can someone chime in on the rear brake resevoir, I know the controls have them integrated but do I run a separate line or something that connects from the controls to the brake? I'm not the greatest on doing major things myself on the bike so I thought id ask.. everything else seems straight forward
Old 07-01-2013, 06:50 PM   #2 (permalink)
madtom421's Avatar
They normally come with a new brake line and a pressure switch banjo bolt. Installation is pretty straight forward. The new line goes from the controls to the rear caliper you don't reuse any of the stock brake set up.
You can be anything you want on the internet, Strange so many people choose to be stupid. -Mark Twain-
Old 07-01-2013, 06:58 PM   #3 (permalink)
LASTCHANCE's Avatar
Here's what it should come with and some FAQs
http://www.phatperformanceparts.com/...ode=PPP-001RSW
LASTCHANCE is offline   Reply With Quote
Old 07-01-2013, 07:51 PM   #4 (permalink)
Don't worry to much. Once you start you will realize how simple it is. Just make sure you use blue loctite as you put your new bolts in.
akwarrior79 is offline   Reply With Quote
Old 07-01-2013, 08:06 PM   #5 (permalink)
Ama
Ama's Avatar
Alright thanks fellas! Ill let you know how it goes
