I'm an idiot - cam cover insert - Road Star Warrior Forum : Yamaha Star Warrior Forums
Old 05-28-2015, 02:48 PM   #1 (permalink)
Send a message via AIM to hgt518 Send a message via Yahoo to hgt518
Default I'm an idiot - cam cover insert
I recently purchased the baron cam cover insert and it did not come with any instructions. I looked online and called customer service but they have been unable to provide instructions yet. I was messing around with it last night and ended up removing the bottom bolt which I don't think your supposed to touch based other threads I found. The whole cam cover came off and I think I may have slightly bent the thin metal gasket inside. I think I was able to get it back on there correctly but I'm worried about having damaged it. I haven't started or ridden the bike yet, how concerned should I be about this? do they sell just that metal gasket if I did damage it? anyone have the insert cover install instructions?
hgt518 is offline   Reply With Quote
Old 05-28-2015, 10:12 PM   #2 (permalink)
tribalMR2's Avatar
You have any pictures, im about to do the same thing.
tribalMR2 is offline   Reply With Quote
Old 05-28-2015, 10:18 PM   #3 (permalink)
I didn't take any pics but only take the 5 bolts out, not 6. The 6th bolt is at 6 o'clock and you don't need to remove it to take the cover off
Old 05-29-2015, 12:45 AM   #4 (permalink)
Ama
Ama's Avatar
I replaced mine as well as the decompression solenoid cover and it was a piece of cake. the only thing u have to be very careful about is this little wire or something where the decompression solenoid cover is not to nick it. im not the most handy guy in the world but those two covers were a piece of cake. what exactly is the issue harrison?
